sr18de flywheel bolt torque settings helpppppp !!!!!
Posted: Sun Dec 11, 2011 12:35 am
by ZimNismoboy34
As the post above says please if any one can help with torque settings for a the Sr18de engine flywheel bolts i have taken off the clutch to do a job on the plate and pressure plate, please can you let me know where i can locate the torque settings for the flywheel bolts .
have searched the net for a workshop manual and suprising cant find anything .
And tried to search for bolt settings but cant find anything as well?
Please can some one helpppp need to put this car back together !!!!
Re: sr18de flywheel bolt torque settings helpppppp !!!!!
Posted: Sun Dec 11, 2011 9:18 am
by ZimNismoboy34
something like 30nm for clutch cover, and like 90 nm for the flywheel .... please correct me if im wrong someone . this spec was for a sr20de.....
Posted: Tue Dec 13, 2011 9:47 am
by Guy
What size and grade are the bolts? eg M10 grade 8.8
From that info torque can be looked up in tables that are available.
A couple here: http://www.cncexpo.com/MetricBoltTorqueNm.aspx
and http://www.imperialsupplies.com/pdf/A_F ... Charts.pdf
Be aware these are general standards, ideally go by the service manual as they may spec a different torque.
