As the post above says please if any one can help with torque settings for a the Sr18de engine flywheel bolts i have taken off the clutch to do a job on the plate and pressure plate, please can you let me know where i can locate the torque settings for the flywheel bolts .
have searched the net for a workshop manual and suprising cant find anything .
And tried to search for bolt settings but cant find anything as well?
Please can some one helpppp need to put this car back together !!!!
sr18de flywheel bolt torque settings helpppppp !!!!!
ZimNismoboy34
ZimNismoboy34
Re: sr18de flywheel bolt torque settings helpppppp !!!!!
something like 30nm for clutch cover, and like 90 nm for the flywheel .... please correct me if im wrong someone . this spec was for a sr20de.....
Guy
What size and grade are the bolts? eg M10 grade 8.8
From that info torque can be looked up in tables that are available.
A couple here: http://www.cncexpo.com/MetricBoltTorqueNm.aspx
and http://www.imperialsupplies.com/pdf/A_F ... Charts.pdf
Be aware these are general standards, ideally go by the service manual as they may spec a different torque.
