S13 window relay box
NIZAN-R
- Real Name: Renier
Re: S13 window relay box
open it and resolder all the components try it
i had 2 loose capcitors in mine stoping it from working
- White Fang
- Real Name: Qubitt (Qbit)
dont burn the starter
Whap Whap
1.3 - i Turbo
No Piston's
No Valve's
1.3 - i Turbo
No Piston's
No Valve's
NIZAN-R
- Real Name: Renier
did you find some loose components and dry joints?
Grant222
- 0.9 Bar Boost
- Engine: 2JZ
- Real Name: Grant Jones
not yet, car is parked in garage cant open door to wide to get the panel off, gota wait till my dad gets home with the keys to move the car behind it
- White Fang
aaaa , you are such a chop !
Whap Whap
1.3 - i Turbo
No Piston's
No Valve's
1.3 - i Turbo
No Piston's
No Valve's
Grant222
- 0.9 Bar Boost
- Engine: 2JZ
FIXED!!!!!!!!!!!!! Thanks Renier!!!! There was a dry joint on one of the connection pins
NIZAN-R
- Real Name: Renier
easy as pie
- White Fang
Renier , send him a bill !
Lat die phokker betaal ! i am sure a set of TE37 will pul the premuim
Whap Whap
1.3 - i Turbo
No Piston's
No Valve's
1.3 - i Turbo
No Piston's
No Valve's
- Charlvdw
Ja and when i told you this i was talking kak....Grant222 wrote:FIXED!!!!!!!!!!!!! Thanks Renier!!!! There was a dry joint on one of the connection pins
