Reason for selling, got a great deal on a motor im going to swop
(most of the stuff must go before i can sell) No parts where ever used to raced, car was stock all its life but very well maintained
Item: Garett T28 Turbo from SR20DET
Condition: Used, Great condition. Stock. Blades are perfect and no play.
Extra: Bolted on to Ca18Det manifold - i would skim the manifold
R2500
Item: CA18DET steel braided oil lines (nice and longish)
Condition: Perfect, bought them and used them for maybe 1000km's
R200
Item: 200sx Ca18Det Afm+Stock air box
Condition: Perfect, no drilled holes etc
R750
Item: CA18DET cam cover
Condition: Great - Seal under neat has just teared
R250
Item: CA18DET CAS
Condition: 100% working
R500
Item: Ca18Det 4 port head + Intake manifold with sensors
Condition: Exh valve guides needs to be replaced
Extra's: Includes basically new Nissan Cam belt
R 1000
Item: S13 Ca18DET engine Ecu and Harness
Condition: Perfect working order and stock, no wires where cut to my knowledge
R 1000
Item: CA18DET fuel rail and 4X 370cc side injectors
Condition: Good working order
R1200
Item: CA18DET complete lower block with pistons ans.
Condition: rear oil seal was leaking slightly, Rings are 100%, add head and go!
R1000
Item: CA18DET clutch
Condition: Has allot of life left. +- 85%
R450
Item: Ca18Det coils X4
Condition: Great working order, never put under strain
R250 each (will only sell in set)
Item: Ca18DET Intake and Exhaust cams
Condition: 100%, very good condition
R600
Eugene Smit
0820801885
eosmit@gmail.com
