Co2 cooling
- k.y.l.e.
- Real Name: kyle
Co2 cooling
I was thinking of a co2 cooling system on the intercooler, basically you have a round copper pipe with small holes drilled or just a spray nozzel pointing directly at the intercooler, connected to a solinoid and on to a 20oz co2 paintball tank, its a cheap modification i read it gives you small amout of power increase, what you guys think any body try it yet
- Devils Parts Store
- Real Name: RB
Re: Co2 cooling
Better to just install a Water/ Methanol kit, gains are way more worth it.
- mario_200sx
- k.y.l.e.
- Real Name: kyle
Re: Co2 cooling
I would love to put a water meth kit in but dont have that much money yet, an the co2 cooling going to cost me under R300
Re: Co2 cooling
For that kind of money yes...
- mario_200sx
Re: Co2 cooling
Then rather leave it as it is.k.y.l.e. wrote:I would love to put a water meth kit in but dont have that much money yet, an the co2 cooling going to cost me under R300
The car doesnt need any extra cooling as long as you keep the boost as is.
Re: Co2 cooling
I beg to differ, even in stock form heat soak is always a problem....this will help, when others start to loose power because of heat...yours will still be strong...for as long as the CO2 lasts...
- mario_200sx
Re: Co2 cooling
Cant see the point of doing this? Its going to last what? 5 minutes? Only time it would be worth using is if you do drags?Draco wrote:I beg to differ, even in stock form heat soak is always a problem....this will help, when others start to loose power because of heat...yours will still be strong...for as long as the CO2 lasts...
Normal use on the road its just not practical.
- k.y.l.e.
- Real Name: kyle
Re: Co2 cooling
Thats the only time i would use it, when i do drag racing, i see you point mario im not going to keep the co2 system running constantly as that would be pointless but only when i drag il use it, and yes im not touching the boost at all to scard.
- k.y.l.e.
- Real Name: kyle
Re: Co2 cooling
Any body know what type of solanoid i need for this setup and were can i get one.
- Drillergy
- Real Name: Darryl
Re: Co2 cooling
What about filling your engine bay with CO2 and getting sucked into the intake?
Could kill your engine.
You can rather get a pump, solenoid and use your windscreen washer bottle as a tank for water/Meth and run it to your intake. Its been done before at a fraction of the cost of a all out pregressive system.
Just m 2c
Just m 2c
- Obsession
- Real Name: What Ever...
Re: Co2 cooling
BASICALLY (And i know, not te same) as the WRX's use, a tank, with a sprayer and a solenoid, and just plain water, spraying over the inter cooler..Optional extra from Subaru if i am not mistaken?? Makes sense.....Drillergy wrote:What about filling your engine bay with CO2 and getting sucked into the intake?
Just m 2c
Uno Turbo(Stock) Stolen!
Uno Turbo(Worked to hell and back..) Sold
1961 ford Anglia Cosworth Sold
Nissan 200sx...Everyday drive..
E46 M3...clutch pack exploded!!!! Need gearbox...
What The F)ck Ever...
Re: Co2 cooling
i'm running both... water/meth and H20 bar by the inter cooler... the way i see it, the cooler the better..
But thats just me.
But thats just me.
