CA18 wont start, cranking like there is no compression
- rat
- Real Name: Rat
Car is stock std. Cranked to start it this morning and it took and sounded like it fired through the intake. Now it sounds like i am cranking with no spark plugs in. What could have gone? Been thinking Cam belt?
- FLANGA200SX
- Real Name: Julz
Re: CA18 wont start, cranking like there is no compression
have you taken a spark plug out to check if its making spark? mybe start there
200sx s13 CA18DET working progress
Toyota Corolla GLS 160i 87Kw 150Nm
- Daniel
- Real Name: Daniël
Aah no, the only reliable S13 is down and out!
Though the way you describe it does make it sound the same as when my timing belt broke.
Now check for spark you bannana
- FLANGA200SX
- Real Name: Julz
did you get the car started and what was the problem?
