(O=O)/RS13\(O=O) "if you only need one jack to raise your car, then your car isn't low enough"
revlimiter that cuts spark instead of feul
for launch control or flat shifting
sr rockers hate it instead of bang bang
cluck break rocker bog noise
Hey guys i did a little research found out putting in a ALS(anti lag system) is bad news for the turbo and exhaust it will kill the exhaust in 10-100km ,and as for the turbo it raises the turbo temperature to 800-1000+ region so i would not go near it,if you really want to shoot flames out the exhaust get a flame kit cost R800, it basically cosist of a spark plug and coil ,it is controled by a button inside the car when you press the button the spark plug ignites the unburnt fuel in your exhaust inturn shooting NICE BLUE FLAME'S with out putting your turbo at risk, the spark plug is placed inside the exhaust.Hope this helps
Current car=s13 200sx with s14 motor sr20detv.v.t.
