S14 Battery light
- shiraazz
S14 Battery light
Just came home now, and saw while i was idling my car the battery light on, when I rev, it gets dim.
Where do I start checking for the problem?
Thanks in advance
Thanks in advance
Driving is not my hobby, it keeps me sane
___________________________________________
Current : 1996 S14 200SX
Will be back : 1999 E39 540i
RIP : 1994 E36 325i
Ex : 2001 Daihatsu Coure 1.0
Ex : 1993 Jetta II
RIP : 1994 E36 325i
Ex : 1993 Jetta II
Re: S14 Battery light
The diode pack has two or three diodes blown. Regulator will be un effected.
There are six on the plate, usually half of them -one phase-pops.
- shiraazz
Will it be ok to drive before i fix it?
RIP : 1994 E36 325i
Ex : 1993 Jetta II
RIP : 1994 E36 325i
Ex : 1993 Jetta II
- White Fang
- Real Name: Qubitt (Qbit)
Fix it , ! or your car will use the battery while ideling !
And only run on alti when you revving it up , So if you idle long enough your battery will die !
Whap Whap
1.3 - i Turbo
No Piston's
No Valve's
1.3 - i Turbo
No Piston's
No Valve's
- shiraazz
I measured the battery this morning, was 14v while idling
RIP : 1994 E36 325i
Ex : 1993 Jetta II
RIP : 1994 E36 325i
Ex : 1993 Jetta II
- White Fang
ok cool , then we can start with all the other small goodies , LOL
Whap Whap
1.3 - i Turbo
No Piston's
No Valve's
1.3 - i Turbo
No Piston's
No Valve's
- shiraazz
Where are the diodes? i need to test them
RIP : 1994 E36 325i
Ex : 1993 Jetta II
RIP : 1994 E36 325i
Ex : 1993 Jetta II
- shiraazz
anyone???
RIP : 1994 E36 325i
Ex : 1993 Jetta II
RIP : 1994 E36 325i
Ex : 1993 Jetta II
Shiraas , the voltage will be 14v even though the diode pack is fubarred.
Diode plate with the diodes attached are within the alternator housing.The plate makes up the rectifier pack for the alternator.
The reason the light starts glowing at low revs is the current demand from the cars electrics. You will find that by testing it on a test bench it will be way down on current supply (amps) when the demand hits.
- POWDER
- Real Name: Mike
Shot for the info Barry, this might help m situation out too...... (Sorry for thread jack)
- White Fang
Shiraaz made a turn at the shop today !
all the wiring on the car is loose and a couple of wires are open and loose !
so i told him to first sort out all the loose wires and tape up all the open wires and sloder them too ,
then we can look at altinator ! lol
Whap Whap
1.3 - i Turbo
No Piston's
No Valve's
1.3 - i Turbo
No Piston's
No Valve's
