motor problems
CC Motorsport
- Real Name: Geoff
motor problems
hey guys
after the track today something is f#*?ed up iv guy no power the is a winy noise and it sound like one of though desiel babies
any help would be great
fast is just not FAST enough
- White Fang
- Real Name: Qubitt (Qbit)
Re: motor problems
aaaah man ! G dude did you have enough oil iin the car ?
Sound 2 me like bearing or cams LOL
ooo and here we start !
Whap Whap
1.3 - i Turbo
No Piston's
No Valve's
1.3 - i Turbo
No Piston's
No Valve's
CC Motorsport
- Real Name: Geoff
Re: motor problems
i just discovered what the problem is the head gasket is blown between 2 cylinders causing some blowing between the 2
CC Motorsport
- Real Name: Geoff
Re: motor problems
where can i get a head gasket for a reasonable price as well as head bolts?
CC Motorsport
- Real Name: Geoff
- Daniel
- Real Name: Daniël
Re: motor problems
aah fack that's not cool bud, hope you come right!
The head gasket from Nissan I feel is very good. But now days you can get a Cometic MLS gasket for the same money if your willing to Import.
CC Motorsport
- Real Name: Geoff
- Drillergy
- Real Name: Darryl
Re: motor problems
Sup CC
Where are you?
I'd recommend if you go mls head gasket like cometic get arp bolts with it.
Also if your HG is gone, you will have to check if the head is not warped.
If it is then you need to skeem it.
If the budget is tight then a Payen HG is fine.
And make sure you flush the radiator as well.
Where are you?
- White Fang
Re: motor problems
ooo nee! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
CC while the head is off somme send it in for some porting !
Whap Whap
1.3 - i Turbo
No Piston's
No Valve's
1.3 - i Turbo
No Piston's
No Valve's
CC Motorsport
- Real Name: Geoff
Re: motor problems
shot for all the imput
ya its unfortunate but i no the hole drill with head gasket problems
Mr fang that's a standard procedure seeing as the motor is down anyways and maybe i should do nos as well
- White Fang
Re: motor problems
Hahahah ! ja go big or go home ! NOS !!!!!!!!!!!!!!!!
Whap Whap
1.3 - i Turbo
No Piston's
No Valve's
1.3 - i Turbo
No Piston's
No Valve's
- Daniel
- Real Name: Daniël
Re: motor problems
Nitrous is like a hot chick with a STD, you know you want to hit it...your just afraid of the consequences!
- White Fang
Re: motor problems
ja ! true ! but its lekke while it lasts !
Whap Whap
1.3 - i Turbo
No Piston's
No Valve's
1.3 - i Turbo
No Piston's
No Valve's
