The 200SX Club List
Going fast in a straight line
Phinx
0.7 Bar Boost
The 200SX Club List
Post by Phinx »
The list as it stands :
1. Draco (S-13)
2. Chemcool (S-13)
3. Phinx (S-13)
Challenges Are welcome, We have to get the ball rolling on this list
So comments are welcome...
Post by Vlade »
I think the rule is you can only get on the list if you race :wink: and post a result...
I know ChemCool said he needs to back out since he has a bearing knock, racing now will just cause an engine to break :cry:
I think another rule is if you can't race the guy above you, because of, unforeseen circumstances you race the guy above him simple as that.
Phinx
0.7 Bar Boost
Post by Phinx »
OK then in that case Draco...
I'm calling you out,
Post by Vlade »
[smilie=200sx_gunsmilie.gif]
widowmaker
Real Name: Walter
Post by widowmaker »
Phinx wrote:OK then in that case Draco...
naa phinx, youre too late, she has come out a while ago
:lol:
Hey Phinx, you will have to take the top spot for now, I blew a head gasget and due to some misunderstanding I now broke some valves and hurt a piston, but be sure when she is running again youl have to defend your spot, be ready :twisted:
jurru meneer.
en nou?
do tell please!
Don't want to go into detail it's a bit sensitive, well sent my head in with Freddy...thanks for the help Fredman and to Vlade and everybody that helped over the phone.
I am now trying to find out if I can re-use the piston or get another old one from someone to replace it with...anyone....just one.
The piston got hurt by the broken valves, it has some nasty dents but not to bad I think and a pease is standing out, the piston is not cracked just abused a bit the small hump i'll grind flush if I can re-use it, I don't want to take out the engine and pistons and stuff, had replaced rings and bearings about a year ago so that should be ok.
Post by Ero_sennin »
usually the say that the "holes/dents" can cause hot spots or something but I'm no expert
Hopefully the water/meth will sort that out....hopefully!
Sorry to say but I doubt it.
So I have to replace the piston...great!
Thats what I would do. And while the motor is open I would fit head studs and a steal head gasket.
The question is where do I get this here without paying R2000
Phinx
0.7 Bar Boost
Post by Phinx »
Why wound you change the head-Gasket to a metal unit?
You are removing a failing point should something go wrong.
For example with a metal gasket you next failing point, should you run into detonation is you piston rings to me a head gasket is cheaper then a piston.
Also most JDM tuners run "stock" nissan gaskets, because if the vehicle is tunned correct it will not blow the gasket.
We are not pushing numbers anywhere closed to what is required for ARP head-bolt and a Metal-head gasket.
Draco why did you drop a vale? Cam belt jump a couple of teeth? Over rev? Bad tension?
