Ca18 to vvl adapter
Ca18 to vvl adapter
Hi there . Does anyone here know where i can purchase an adapter plate to fit a fwd vvl engine to my ca18 rwd gearbox? I am looking to build something with a smooth idle as i enjoy knocking about with the sx daily. Any info appreciated.
Ca18 to vvl adapter
The sr bellhousing from the rwd box bolted to the ca box will allow you to bolt the ca box to any sr engine
- VeNoMiZeR
- 0.2 Bar Boost
Re: Ca18 to vvl adapter
fwd vvl block is different but can be modified to fit the gearbox , i tried aswell wanted to use a pulsar but the block is different and the starter sits on top and not at the bottom
Current: 93 Pulsar SSS N14 Japspec (in Progress)
Ex:Nissan 300zx z32
Nissan S13 200sx SR20det
Nissan Sentra 200sti Neo Vvl
Nissan 200zr RB25det
Nissan 300zx z31 Vg30et
Ex:Nissan 300zx z32
I wanted to use a adapter plate as i want to use cas to run the abs and dash. I am also using std preasure plate but making it twin clutch plate so i need extra depth inside bellhousing. The sr bellhousing does not lign up perfectly causing clutch plate boss to fail. I would like to do something that looks neat as well. I saw a guy hack the bellhousing and it worked for him but i am not that type of enthusiast.
Ca18 to vvl adapter
You would have to go for something custom then
I will chat to Warren at BSE , he might be able to assist. Thanx
