lest door as some rust on the outside skin easy to fix
i want R2500 for the set
semi complete ca18det 4port head
its missing-injectors
and cam caps on exhaust side
R900
ca18det clutch fan R100
ca18det perfect coil harness R100
ca18det pre-made dictator harness R250
saab vacuum pump to controll the butterflies for the 8 port R250
complete ca18det just needs to be pulled out the car R3k and 1k for box
the motor has done 190k km has a t25g topmount turbo and is 8port
anyother s13 parts you may need just ask
nissan j30 calipers 2pot front with 30mm slotted brake discs with new pads R2000 for set direct bolt on
