S14 Stalling
Buckusa
S14 Stalling
Post by Buckusa »
Hi guys, need advice please. My S14 is recently stalling Intermittently. So while I am driving at idle it starts to choke and even if I hit the throttle it like suffocates and dies. Thing is though it does not do it all the time. then when it dies it sometimes starts up fine and other times it will just swing and not start and will only start after a few minutes. I have recently done the service changing the plugs also same thing. Any idea why it would do this? :(
Red S14
aep886
Real Name: Davey
Post by aep886 »
maybe the AFM
current vehicles...
1979 Corolla SR5
1996 S14 200sx
Buckusa
Post by Buckusa »
aep886 wrote:maybe the AFM
Thanks Boet, thing is I have another AFM that I tested when I had issues with overfueling and it did make a difference with that. Perhaps I should try it again and see.
Red S14
"starts up fine and other times it will just swing and not start and will only start after a few minutes"
A possible cause could be a failing fuel pump as well..Just throwing it out there..
djtreble
Post by djtreble »
Check all your pipes for splits
www.rotawheels.co.za
www.kaihatsu.co.za
Buckusa
Post by Buckusa »
BigKriss wrote:"starts up fine and other times it will just swing and not start and will only start after a few minutes"
thanks dude, what about the fuel filter I have not changed that? where is located? :oops:
Red S14
Buckusa
Post by Buckusa »
djtreble wrote:Check all your pipes for splits
I did have a look and couldnt see anything out of the ordinary.
Red S14
djtreble
Post by djtreble »
I think it is a failing fuel pump...
www.kaihatsu.co.za
aep886
Real Name: Davey
Post by aep886 »
i think this is the same story with my sentra~!
current vehicles...
1979 Corolla SR5
1996 S14 200sx
phoenix s14
Real Name: Mark Appelgryn
Post by phoenix s14 »
Check the throttle position sensor also. Had issues when I changed the throttle body on my S14. Some small adjustments to make sure the consult says TPS closed when closed and a new map and all was sorted.
Buckusa
Post by Buckusa »
phoenix s14 wrote:Check the throttle position sensor also. Had issues when I changed the throttle body on my S14. Some small adjustments to make sure the consult says TPS closed when closed and a new map and all was sorted.
Ok thanks but im not sure how and what to check onthe TPS?
Red S14
Buckusa
Post by Buckusa »
oh and I found this but this was like this since I bought the car, there is a slight crack on the one of the coil packs, can this be causing it?
Image[/img]
Red S14
NIZAN-R
Real Name: Renier
Post by NIZAN-R »
:shock: that is toasted
poizen
Real Name: Mical Mackay
Post by poizen »
Nice super bright yellow crocs you sunglasses on
phoenix s14
Coilpack will missfire badly like that. As a cheap fix you can try resealing it with silicone gasket. Had a similar problem on my friend's car. Because he has to drive it everyday we resealed it with silicone and then schrunk some sleeving around it. it stopped the missfire but he replaced it eventually. :wink:
On the point of the TPS - you need to check the resistance between the pins. on a SR it is between pin B and C. and I think it has to be 0.7k or something. Am sure someone can help you with details on how to check it.
:wink:
