SR20DE CAMS or Just the intake one
phoenix s14
Real Name: Mark Appelgryn
Post by phoenix s14 »
Hi Guys,
I need a new cam. But I am looking for the 10mm lift intake cam off a SR20DE (I think it came on the first sentras - I think it was the high port motors with the throttle body at the bottom) So if you have one I would need to measure the lobes. the difference from side to side and top to bottom of the lobe should be 10mm and not 9mm or 9.4mm. And then I would like to buy it from you. :lol:
Will buy a set if I cannot get just the intake one. If you have any ideas where I can get one that would also be helpfull.
Thanks.
phoenix s14
sorry edited... high port cams. the motor with the throttle body at the bottom of the manifold like this one:
phoenix s14
Got a set no longer need thanks. :wink:
