Hi to all
I own a 92 200sx sr13 and the car does not accelerate smoothly
between 3000 to 4000rpm.Below and above this range its perfect.
When accelerating slowly it less noticeable,but as soon as more than half throttle is applied it becomes very annoying.
Any suggestions?
Regards
Riaan
SR13 jerking between 3000 - 4000rpm
- Toby
- Club Founder
- Real Name: Toby Kurien
Very likely that your CAS might need overhauling. Look here:
http://tobykurien.com/phpBB2/viewtopic. ... sc&start=0
Changed the plugs from 6es to 7es,made no diff,will replace the fuel filter this w-end, opened up the cas, bearings still perfect, so is the rotor plate ,anything specific I should check on the cas?
- ChemCool
Being a newbie, tell us where are you from. Who and what??? Profile? check this out:http://200sx.za.net/phpBB2/viewtopic.php?t=487&start=0Changed the plugs from 6es to 7es,made no diff,will replace the fuel filter this w-end, opened up the cas, bearings still perfect, so is the rotor plate ,anything specific I should check on the cas?
download the service manual and check everything.
its more than likely to be something thats related to something else, and so on and so on, until you find that the reason that your RS13
jerks between 3-4krpm is because your glasses are not set right.
so go to an optometrist...
i know my logic is wierd, but you will find that once you can focus properly on the words in the manual, you will realise that you should have checked the CAS in a clockwise rotation, not an anticlockwise one!!!
very very vvvvveeeeerrrrryyyyyyy dodgy dude. remind me to keep a safe follwoing distance!ChemCool wrote:Rules are there to break.I have done both left and right
and it sounds like you need to retune your tv!!!!ChemCool wrote: and enjoyed the flickering sound all over
