urgent advice needed
Posted: Fri Apr 01, 2011 10:50 pm
by sean
I got a ca18det with a T28 turbo.I still got pretty much everything standard bt she still isn't running ryt.the idleing is horrible off.wat is the next step 2 making her faster an better.gotec? Dumpvalve? Wats the next steps?
Re: urgent advice needed
Posted: Fri Apr 01, 2011 10:53 pm
by aep886
sean wrote:I got a ca18det with a T28 turbo.I still got pretty much everything standard bt she still isn't running ryt.the idleing is horrible off.wat is the next step 2 making her faster an better.gotec? Dumpvalve? Wats the next steps?
do stage 1 first~! filter and exhuast!
stage 2 is intercooler and ECU
Posted: Sat Apr 02, 2011 8:09 am
by BigKriss
Sean, get the std. stuff working 100 % first. Idling problems could be air flow meter leaks, messed injectors, fuel pump pressure, ignition system, a myriad of possible causes..
Once its running as it should stock, then start "upgrading" things.
My 2c worth.
Posted: Mon Apr 04, 2011 8:48 am
by P3g4sus
BigKriss wrote:Sean, get the std. stuff working 100 % first. Idling problems could be air flow meter leaks, messed injectors, fuel pump pressure, ignition system, a myriad of possible causes..
My 2c worth.
Agreed
Posted: Wed Apr 06, 2011 6:02 am
by POWDER
My 2c worth.
Agreed
Best advice that, otherwise u sit like me for 2 years doing all the nice things, but never solving the problem, he he he, it is fun though, lol :twisted:
