Battery relocation
- aep886
- Real Name: Davey
Battery relocation
guys...
i need some info on the battery relocation....
what cable should i use? do i really need a box for it?
and what connector ...ect....
current vehicles...
1979 Corolla SR5
1996 S14 200sx
1979 Corolla SR5
1996 S14 200sx
- POWDER
- Real Name: Mike
Hey guyz, you will require 0ga cable to move the battery, this is due to the extra length causing resistance on the standard 4ga cable.
The box is a good idea to keep any battery acid leaks from ruining your paint n metal at the back, plastic box being the best for obvious reasons......
Make sure to bolt the neg. Terminal directly to the chassis at the back with a short as possible cable also being 0ga.
For the Pos. 0ga cable, it is best to not mess with your original harness, so lay it all the way to the front and solder and clamp to the original pos. 4ga cable as close to the first split as possible.
A good idea would also be to use NEW terminals on the battery it self to improve connection, especialy if the original ones have corrosion or acid residue on them...
Hope this helps.
I have sofar upgraded the existing power ground and pos. And trust me, the Pos. Harness will drive u mad if replacing totally.... Connection, connection, connection.... Must be done right, no shortcuts.....
Am looking at doing rear battery myself soon.
Post pics when you done.....
EDIT: P.S. Run the cable down the left side if you still wanna install sound. Can not run on same side as RCA's and most power wires run on the left so keep it uniform.
Hope this helps.
- aep886
- Real Name: Davey
i was told... 4 or 8 guage cable for postive and 0 guage for negetive...POWDER wrote:Hey guyz, you will require 0ga cable to move the battery, this is due to the extra length causing resistance on the standard 4ga cable.
Hope this helps.
current vehicles...
1979 Corolla SR5
1996 S14 200sx
1979 Corolla SR5
1996 S14 200sx
