BO 1 Dump ValveSpecification and part list
Aluminium Body
Aluminium Piston
Base is 50mm O.D. – machined from High Grade
Aluminium
Small and compact - ensures easy fitment – Fits on 50mm
Silicone hose
Works with two Seals on 35mm Aluminium Piston with
tolerance that ensures no leakage when held close under
vacuum.
Great sound when dumping into atmosphere
Pat Number and trade mark engraved
Sequential option also available to eliminate pressure loss
in system and prevents vehicle going into limp mode
Available in the following colours, Red, Blue, Black, Silver
and Gun Metal Grey. Other colours available on request.
R500
Super Sequential Dump ValveSpecification and part list
Aluminium Body
Aluminium Piston
Bottom sockets available in 38mm Stainless steel or
Aluminium
Works with two Seals on 35mmAluminium Piston with
Fine tolerance that ensures no leakage when held close
under vacuum.
Double acting Cylinder to ensure no leakage on idle
Work’s well on all vehicles with airflow meters
Eliminates limp mode
Recirculating option available upon request
R700
38 mm Waste gate Specification and part list
Aluminium Body
Cast Iron Base
Same bolt pattern as Tail & Turbonetics Waste Gates
38 mm Valve with extra 6mm lift on valve
Valve with special coating machined from solid Stainless
Steel 304.
Inner Bush made from Stainless steel 304
Works with Seal and Piston – No Diaphragm
Special PTF seal can withstand pressures up to 10 bar
and temperature range up to 700 degree Celsius.
Waste Gate good for power up to 600BHP
Can fit boost controller to Waste Gate
R1450
Silicone vacuum hose R20 pm
Contact Johnny: www.xcellperformance@gmail.com
Mention in your email that you were refered by Derek from 200sx club
