S/S bottom mount manifold, T28 Turbo, ventury *SOLD*
Posted: Thu Feb 17, 2011 3:51 pm
SOLD
I have the following for sale, T28 turbo with AR60 compressor housing, AR48 exhaust housing, 76mm s/s downpipe, stainless steel bottom mount manifold, ventury for T28.
Some play on turbo but it did not indicate that the seals were gone, "had some smoke in the mornings but that started directly after I installed the bigger injectors so I suspect it's fuel related" EDIT: smoke is still there after new turbo was fitted so had nothing to do with turbo....whatever the case is I would recommend you get the turbo to a professional to get a once over, actuator might need some work, if you boost 1 bar you had 0.7 bar boost till 5000rmp and then it went to a bar, my diagnosis is that it's the actuator spring.
I want to sell as a package for R3150.
Seperate prices: Turbo without ventury R1700
S/S mani R1200
ventury R250
Ventury:
T28 Turbo,mani and down pipe:
Posted: Thu Feb 17, 2011 4:08 pm
does the stock oil and water lines line up?
Posted: Thu Feb 17, 2011 4:09 pm
I used braided hoses so I am not sure....
Posted: Fri Feb 18, 2011 12:01 pm
Maak skoon die ding.
Posted: Fri Feb 18, 2011 2:45 pm
by djtreble
rat wrote:does the stock oil and water lines line up?
No you need braided lines to prevent bending the standard lines to a point when they break or kink. Braided is better anyway so kill two birds with 1 stone and change them at the same time
Posted: Mon Feb 21, 2011 8:51 am
bump
Posted: Wed Feb 23, 2011 8:17 am
woes
Posted: Wed Feb 23, 2011 7:06 pm
by Wicked
Draco, Pm Sent
Please hold it for me.
Posted: Thu Feb 24, 2011 9:05 am
Replied....
