I have the following for sale, T28 turbo with AR60 compressor housing, AR48 exhaust housing, 76mm s/s downpipe, stainless steel bottom mount manifold, ventury for T28.
Some play on turbo but it did not indicate that the seals were gone, "had some smoke in the mornings but that started directly after I installed the bigger injectors so I suspect it's fuel related" EDIT: smoke is still there after new turbo was fitted so had nothing to do with turbo....whatever the case is I would recommend you get the turbo to a professional to get a once over, actuator might need some work, if you boost 1 bar you had 0.7 bar boost till 5000rmp and then it went to a bar, my diagnosis is that it's the actuator spring.
I want to sell as a package for R3150.
Seperate prices: Turbo without ventury R1700
S/S mani R1200
ventury R250
Ventury:
T28 Turbo,mani and down pipe:
