Cooling
Enzio
Cooling
Post by Enzio »
Having just fitted my FMIC and oil cooler ahead of my radiator, my radiator is suffering a bit as expected.
For those that have done these mods is merely fitting an Al radiator sufficient?
Obviously the flow through the radiator is not great after modding the bumper and fitting averything, so will look at restoring the flow through the radiator by closing up the gaps between the bumper and radiator.
I've got a BMW electric fan in already running off a Honda fan switch (85deg IIRC) located on the thermostat housing.
POWDER
Real Name: Mike
Post by POWDER »
Hi Enzio
I would suggest putting in a geugot fan switch and an S14 twin core alu radiator with twin 12" fans. Mine stays ice cold and takes ages to warm up like that, also geugot fan switch opens at +/- 65 - 70 deg, 85 is too late for these motors. I would also put one fan on a jumper switch sothat if you you know you gonna be driving hard, you can flick the switch to make it run constantly. This will then imitate the best fan settup for the car (the original clutch fan).
O and yes, air guides are also very nice to have :)
I you got a bm radiator fan and not the air con fan, you cant improve on that.
Two 12'' don't come close to the 15'+ beamer fan. Get the oil cooler out of the way and fit a alu radiator. The CA radiator for the S13 is thicker then the SR/S13 radiator. 76 degree fan switch should be fine.
POWDER
Real Name: Mike
Post by POWDER »
Sorry didn't know diamiter of beemer fan, definatly, 15" should work great.....
NIZAN-R
Real Name: Renier
Post by NIZAN-R »
had mine (ca18det) cleaned at a radiator shop never heated up again
Enzio
Post by Enzio »
Yeah, the BMW fan is a good one. Will have look in the meantime.
aep886
Real Name: Davey
Post by aep886 »
it time for a V-mount^^
current vehicles...
1979 Corolla SR5
1996 S14 200sx
POWDER
Real Name: Mike
Post by POWDER »
aep886 wrote:it time for a V-mount^^
+1
Enzio
Post by Enzio »
Uhhh, no. Massive cost and fabrication to do it properly for a small gain.
Even hardcore setups don't have to go v-mount.
aep886
Real Name: Davey
Post by aep886 »
the cost of the V-mount might be high... but you will put smile on your face^^... the shorter ic piping will give you much more response then your FMIC
current vehicles...
1979 Corolla SR5
1996 S14 200sx
