200sx 1.8 - Tech needed
Hi There. Where can I take my SX for a service ? Obviously don't want any poepol working on her.
I live in Rustenburg.
- poizen
- Real Name: Mical Mackay
you will have to unbolt the ecu (passenger side kick pannel) at the back there is a screwHunterNW wrote:HE HE, sounds like it could be anything. Where do I see the error code ?
Sorry - Me and the SX are a new couple.
youll need to turn it all the way clockwise you see flashing red and green leds
red/greenx1 -mode 1 (ment for automatics)
red/greenx2 -mode 2 (forgot it never used it)
red/greenx3-mode 3 9this is the code mode)
one you seen both leds flash 3 times turn the screw all the way anticlockwise this locks in the mode
next you'll see the codes flash in led sequence what you want is a code 55
5x red led flashes followed by 5x green led flashes
so you basically get the idea
1xred flash and 3x green flash is code 13 ( cas or airflow i think cnt remember of hand)
once you read the code turn the screw clockwise again or switch off
p.s i dnt know if i was correct with the screw in which way you turn but you got 50% chance of getting right first time if it didn't work try reverse the sequence
