Urgent Dicktator Help Required
- POWDER
- Real Name: Mike
Hey Guys,
I need bigtime help, Dicktator is wired and getting spark, have replaced Blown module and have a new coil pack running now instead of SR coils. Car still cuts out at 4500RPM as if limiting even though rev limiter is set to 7100. Brand new dicktator ignition module getting very hot very quick, running the 2 coil pack on a 4 ch module on ch 1 + 2.
What can be wrong? It seems I can't get to the point of this and like I'm never gonna get it running.
Please help !!!!
Please help !!!!
- RudeBoy
- 0.5 Bar Boost
what type of coil pack you running? two cylinders per coil?
cyl1 and 4 / and cyl 2 +3
when you say 4ch, you mean 4 coil / 2 trigger module?
if so you would need to wire 2 triggers from dicktator to module
yellow/black to input 1 and wire 1 of the two outputs triggered by input 1 to coil1/4
then connect yellow/green to input 2 and 1 of the 2 outputs triggerd by input 2 to coil 2/3
hope this helps
remember some opel coil packs dont work with ignitors (alu base)
hope this helps
- POWDER
- Real Name: Mike
Module sitting against firewallpoizen wrote:where is your module sitting
what load is the coils drawing
hows your earth its the most important part to the moduls life
Don't know what load
Module earthed directly to chassis with short 20cm lead
- POWDER
- Real Name: Mike
RudeBoy wrote:what type of coil pack you running? two cylinders per coil?
cyl1 and 4 / and cyl 2 +3 - YUP THAT'S IT
when you say 4ch, you mean 4 coil / 2 trigger module? YUP THATS IT
if so you would need to wire 2 triggers from dicktator to module - THAT'S AS IT IS
yellow/black to input 1 and wire 1 of the two outputs triggered by input 1 to coil1/4 - THAT'S LIKE THAT TOO
then connect yellow/green to input 2 and 1 of the 2 outputs triggerd by input 2 to coil 2/3 - THAT'S AS U SAY AS WELL
hope this helps
remember some opel coil packs dont work with ignitors (alu base) NOT AN OPEL ONE IT ANOTHER MAKE NOT SURE
- POWDER
- Real Name: Mike
Sorry for the CAPS in my reply to you RudeBoy, just to show diff between ur question and my answer, not shouting.....
- thekoukimonster
[quote="RudeBoy"]what type of coil pack you running? two cylinders per coil?
hope this helps
remember some opel coil packs dont work with ignitors (alu base)[/quote
I'm in the same boat as powder
, I'm also using the dictator 4ch ignitor.
Will the opel astra ecotec 2.0 coilpack work ? , or if I want to use 4msd coils,
What msd coils should I get ?
hope this helps
- RudeBoy
- 0.5 Bar Boost
for msd use these https://www.msdignition.com/Products/Co ... Style.aspx
turbo & nos stocks these, remember to get the base that goes with the coil
- thekoukimonster
- POWDER
- Real Name: Mike
Yup thats it
