RB25DET s13 help
nirvash
1.0 Bar Boost
Real Name: Andreas
RB25DET s13 help
Post by nirvash »
hi everyone
my RB25DET s13 is giving me abit of trouble...
today when i tried to start it, it took longer for the engine to actually start and turnover, then when it did start it started with a big puff of white smoke, the idled rough. very jumpy idol. i swithched it of then tried again and same thing, then car died and doesnt want to satrt again, theres ignition and the car seems like it wants to start but wont....
any helpand diagnosis guys plz
thanks
Current. CA18DET S13
Yeah, your engine is scrap now mate...
best give it to me :wink:
Your certain there's good spark?
I had a similar issue with my CA when it was over fueling like a mofo, that was my own fault however.
You didnt do "work" in the bay just before the problem started did you?
nirvash
1.0 Bar Boost
Real Name: Andreas
Post by nirvash »
well firstly my engine is over fueling, i get about 250-300kms a tank!
secondly, the only "work" ive done is drain and refill the cooling system then bleed the cooling system, and that was done a couple weeks ago and it was "fine" after that.
i must also add that my car has been running hot of late (so i havent driven it much at all lately and if so not far enough to let it get hot).
themostat works
radiator is fine
looking at getting a new water pump now as it looks like the water flow in my rad is not really good
any ideas?
i dont want to do anything further and possibly damage my engine...
rb25 s13 sx
Newbie
rb25 help
Post by rb25 s13 sx »
if you are running a dicktator check your red wire thats in your harnes that plugs into your managment its a bit thick if im noy mistaken and also you need to check if your map on your managment is still ok heating up can be caused by timing hence i say have your map checked.
aep886
Real Name: Davey
Post by aep886 »
similar thing happen to mine... was the spark plugs... changed them and it fires up like normal....
current vehicles...
1979 Corolla SR5
1996 S14 200sx
ljS14
Car: Evo
Real Name: Shane
Post by ljS14 »
You have fould the plugs :wink: Change them and all will be fine ,if not then then post again :wink:
Usaul Dicktator problem :roll:
Mine just had the same problem starting up after a month or two standing :x
1991 S13 200SX
1993 Z32 300ZX Convertable
Evo 8
FUEL PERFORMANCE
Post by FUEL PERFORMANCE »
New Plugs should sort it !
....And while you at it throw out that Piece of SH%T Dicktator :lol: :lol:
FUEL PERFORMANCE SA-UK-EU
HIGH FLOW SA-UK-EU
nirvash
1.0 Bar Boost
Real Name: Andreas
Post by nirvash »
thanks guys
but what i dont understand is why now suddenly, i havent played with the plugs since the engine swop over half a year ago?
can anyone suggest a good replacement plug?NGK?also which ones?
thanks again
aep886
Real Name: Davey
Post by aep886 »
nirvash wrote:thanks guys
thanks again
NGK idrium^^ surely will do~
current vehicles...
1979 Corolla SR5
1996 S14 200sx
nirvash
1.0 Bar Boost
Real Name: Andreas
Post by nirvash »
will start by changing the plugs. hope it works
thanks all
nirvash
1.0 Bar Boost
Real Name: Andreas
Post by nirvash »
could somebody explain more about a car running hot because of timing and my fuel map??
also which heat range NGK iridiums must i use, and anything else in particular i need to look 4 in them?
Skylinefreak
Post by Skylinefreak »
Too little fuel or too much timing advance will cause it to run hotter than it should. And that can cause detonation which equals bye-bye RB25.
nirvash
1.0 Bar Boost
Real Name: Andreas
Post by nirvash »
thanks
been meaning to get my engine tuned for better fuel economy and a little more boost, so i guess thats on the list now as well. retune
start with plugs, 0.8 gap
under 1bar bcpr6es
over 1bar bcpr7es
ljS14
Car: Evo
Real Name: Shane
Post by ljS14 »
Elroy is comming down in a few weeks time to tune some cars ,good timing :wink:
Contact RB25SX to book a time ,we not sure what date yet.
1991 S13 200SX
Evo 8
