Haltech E11V2 SOLD
Haltech E11V2 SOLD
Hi Guys,
I have two E11V2 kits available. These Units have everything under the sun and are brand new.
Heres a review and you can do some searches on the net.
http://www.dragsport.com/issue/2007/0607_tech.shtml
6 LS1 Coils (valued at R3500)
Map , Air and Water Sensor
R32/R3 Plug and Play Harness (1500)
Has all the features as the New Platinum Series but much much cheaper at this price.
Haltech entry level stand alone ECU without accessories go for more than 1500 Dollars
R8800.00 Not Negotiable. PM Me.
New Haltech Dual Wideband Kit- 2 Sensors
Optional Extra:
New Haltech Dual Wideband Kit- 2 x Wideband Sensors
R2950.00
Allows for Auto AFR tuning with the E11v2. Also Compatible with other Stand Alones that support Wideband.
Also has Analog output
R2950.00
Some Features
Some Features to tickle your taste buds
Review:
http://www.youtube.com/watch?v=7a93MoQvquk
Fully user-definable 32 x 32 mapping ( Up to 1024 points)
- Wideband "Auto tuning" using user definable target AFR table - Narrow and Wideband closed loop O2 control - Staged injection control for multiple injectors per cylinder (inc rotary)
- 3D mapped rotary engine ignition split
- Soft and hard cut rev limiter
- Tuning via TPS with manifold pressure correction
- Dual map switching for fuel/ign/boost
- Anti-lag (Rally and Launch style)
- Rotational idle
- Launch Control - VTEC cam timing control
- VANOS cam control (intake cam only)
- True variable cam control supporting late model Toyota's, WRX's and EVO's
- Dual intake runner control
- Onboard 3 BAR MAP sensor
- Custom sensor calibration (Use your own sensors for temps or fuel/oil pressure etc)
- Open or closed loop boost control ( Road speed, RPM or gear based mapping)
- Closed loop idle control (Stepper motor and BAC type)
- Extra injector control
- Thermo-fan control ( Duty cycle or on/off )
- Intercooler fan/spray
- Alternator control (Mazda)
- Engine control relay function
- Nitrous switching with fuel / ignition correction
- Staged shift lights
- Aux fuel pump control
- Tacho output (5v,8v,12v)
- Turbo timer
- Torque converter lock up
- Air con request idle up
Review:
- Rotational idle
- Turbo timer
Update
Ls1 Coils Sold.
R1850 Discount on the E11v2 without coils. If you want coils. You can get them from Haltech for around 50 dollars each.
I have a LM1 innovate kit that will work this unit and other ecu's. Has analog output Its 2nd hand but new condition. R1000.00. Also selling separately
PM Me.
PM Me.
