So I have a 4aFe motor and in the process of stripping it to fix the Bearings etc.
I tthe head will be opened I want to get it painted.
Maybe a design of the rising sun or go chrome...
What paint to use?
What preparation should be taken before applying paint?
What materials shold be used to clead and prepare surface for paint?
Any other advice and comments will be helpfull thank you
Painting the head/rockercover??
- Captian
- Engine: 1JZ
"Life is simple.You make choices,and you don't look back."Han-Tokyo Drift
"If you want the ultimate, you've got to be willing to pay the ultimate price.
It's not tragic to die doing what you love" Bodhi-Point Break
- Captian
- Engine: 1JZ
Did you do it yourself or send it in?aep886 wrote:you got to use heat resistant paint on the rock cover...
or do what i did... i powder coat mine ^^ and it awesome~!
Is yours a single colour?
- poizen
- Real Name: Mical Mackay
any paint is prep work
you need to sand down the cover make sure it smooth then clean it with thinners
after that get yourself 2k car paint spray a decent primer on then let dry then spray the 2k over
you dnt need heat resistant 2k lasted over a year on my ca and still going strong after all our cars sit in hot sun all day
- smoothedgp
- Real Name: F.J Steenberg
Well i sand blasted mine with baking soda to clear off all crap,then washed it with a engine cleaner.high heat primer,then high heat paint and then clear.that way i didnt have to sand down anything.shout if you need help.
http://www.jdmsyndicate.co.za
1992 Black Gtr32
2005 530d
1992 Black Gtr32
2005 530d
- Captian
- Engine: 1JZ
Thanks alot guys
Will give you a shout as soon as I have sorted the engine.
http://www.fueltopia.co.uk/profiles/blo ... ockercover
- smoothedgp
Easier to do the tins if they off,so while they putting the motor back together work it out takes about 2 days in paint,polishing takes 4-5 days depending on what part it is.
1992 Black Gtr32
2005 530d
1992 Black Gtr32
2005 530d
- Captian
- Engine: 1JZ
Dont want them to scrach the paint with chains etcsmoothedgp wrote:Easier to do the tins if they off,so while they putting the motor back together work it out takes about 2 days in paint,polishing takes 4-5 days depending on what part it is.
