Mail Me!
Magnetic drain plugs attract and hold metal particles that circulate through your oil system before they get a chance to cause severe engine damage.
No matter if your engine has 5 or 500,000 miles on in you need to be running a magnetic drain plug. The constant flaking effect that the normal wear of moving parts creates is enough metal content in your oil to accelerate engine wear, a magnetic drain plug catches these particles before they recirculate throughout the engine. If something more severe is going wrong in the engine, your drain plug will give you an early warning! Be able to monitor engine life. Why let your motor be destroyed by a stupid metal shaving being carried all over the inside of your high dollar motor that could clog up an oil passage! We all know what happens when a motor doesn't get oil. BOOM!!! Avoid paying huge amounts to repair that blown motor.
