low oil pressure...
- aep886
- Real Name: Davey
low oil pressure...
how do i increase my oil pressure... my motor needs much more oil
you mean you need more flow? higher than stock oil pressure is not nessesarily a good thing..
but higher pressure (within limits) can be achieved by shiming the release valve on the stock oil pump, or replacing the stock spring with a stiffer one.
for more flow you will need a uprated/high flow oil pump, if there is even one avaid for the engine you are looking at.
300zx fairlady 1991
200sx s13 with vg30det @ 1bar
