sold
- FUEL PERFORMANCE
- FUEL PERFORMANCE
- mario_200sx
- FUEL PERFORMANCE
WHAT IT DOES
The AEM Water/Methanol Injection System injects a mixture of water/methanol into the intake of a forced induction engine. Injecting water/methanol allows users to run more boost and ignition timing to gain horsepower and torque. Gains as much as 20% more horsepower and 25% more torque on pump gas are common.
WHY YOU WANT ONE
The AEM Water/Methanol Injection System comes loaded with more STANDARD features and high quality components that any other comparably priced injection system on the market today. The AEM injection kit comes with a 1 gallon tank with built-in low level switch. The "Boost Safe" injection readiness system comes standard in all AEM Water/Methanol Injection Systems. A check valve that prevents unintended fluid flow is included standard. One injector and three interchangeable nozzles are included to cover a wide range of potential horsepower levels along with 20 feet of injection tubing to facilitate the system being installed on practically any vehicle.
KEY FEATURES
· 1 Gallon tank with built in low level switch
· Boost referenced progressive controller
· “Boost Safe” readiness safety system
· Check valve to prevent unintended fluid flow
· One injector and three nozzles to cover a wide range of HP levels
· High Pressure Recirculation-style pump
· LED dash light for system status and low fluid warning
· 20 ft. of injection tubing
3 Left
WHY YOU WANT ONE
KEY FEATURES
3 Left
plane^driver
Which pump does the kit comes with? Is it the new 30-3014 pump like this kit?
http://www.aemonly.com/water-meth-injec ... t-247.html
- FUEL PERFORMANCE
FUEL PERFORMANCE SA-UK-EU
HIGH FLOW SA-UK-EU
HIGH FLOW SA-UK-EU
