Dynotech
Andrew.200SX
Dynotech
Post by Andrew.200SX »
Well , I finally got around to dropping my SX at Dynotech for remapping of the management with the new turbo and higher boost.
I am like a kid on Christmas eve , can't wait to get the "BEAST" back !!
I will post power readings and arse whippings when done !!!
:twisted: :twisted: :twisted: :twisted: :twisted:
ljS14
Car: Evo
Real Name: Shane
Post by ljS14 »
Was there last Sat ,Some really hot cars there ATM 8)
1991 S13 200SX
1993 Z32 300ZX Convertable
Evo 8
Andrew.200SX
Yeah , walked in there yesterday with "houding" because of my windgat SX and got met by not 1 but 2 RX7's and a Noble ,amongst other things.
Got humbled pretty quickly.
:shock:
Andrew.200SX
Dyno tuning SR20DET
Got the car back this afternoon , and now I can also highly reccomend Izak at Dynotech. The car is running beautifully now.
As I originally suspected the original dyno kw reading that the previous owner gave me was bullshit. Stock standard SR20DET with the standard T25G turbo and he told me 204 kw's.
I haven't done anything to the engine itself , it is still standard , I have only added a WR280 T28/ T3 turbo .
The car is running now at .9 bar and putting out 191 kw's and 360 nm.
The nice thing is that it now runs smoothly all the way up to the redline with ease.
Very impressed with Izak. Now I am on the hunt for ways to get more power without breaking the bank !!
IDEAS ?!?!?? :?: :idea:
n1smo200sx
Post by n1smo200sx »
byno sheet?
Power seems bit low for 0.9 and nm bit high.
Mine made 245rwkw 392nm on 0.95
Redtop or VVL Sr?
mods?
Andrew.200SX
Dyno sheet shows 191 kw @ 5713 rpm and 348 nm @ 4733 rpm
It was over 200 kw's , but Izak said that it was "pinging" , so he brought it back down.
It is a redtop SR and I haven't done anything to the motor, it is still standard.
your 245 kw at the wheels seems a bit high. What turbo and mods were you running ?
n1smo200sx
0.8 and 0.95
Andrew.200SX
What mods and turbo are you running ?
n1smo200sx
like to see the graph of the power to compare it.
Check my garage,most of it is listed there.
Andrew.200SX
I will take a picture of the printout shortly and load it up , but the power line runs fairly straight , not as much of a spike as yours.
The turbo isn't what I originally expected it to be. Still runs bloody well though. Basically no lag at all, from pull off smooth power all the way , no hidden surprises , just runs pretty quick.
Andrew.200SX
If I look at some of the power readings from a previous dyno day on the same Dyno , then it isn't bad at all......
2000cc-2400cc Forced induction KW NM
Luc Luchesci - opel Kadett 200ts 219 468[/i]
ebrahim Vesamian - Opel coupe turbo2 204.8 450
Shawn Smit - Audi A4 2l t 183 333
michael Francisco - Nissan 200sx 183.9 382
Jean-Pierre - S14 Nissan sx 181.8 311
Ruan chamberlain - Audi A3 2l t 180 350
Charl Cillie - Opel Astra OPC 174.2 359
Jaco Nieuwa - Audi A3 2l t 172 345
Denzil Blegenhout - Nissan 200sx 156 272
Jonothan Michael - opel Kadett 200ts 156 272
ljS14
Car: Evo
Real Name: Shane
Post by ljS14 »
Had my evo on that dyno ,It reads lower then most of the CT dyno's .
If you make 190kw then its very strong.
My kw is low but the NM is high like yours :wink:
Look at Luc's kw ,he gets over 300kw on other dyno's :wink:
1991 S13 200SX
Evo 8
Andrew.200SX
Thanks man.
I suspected as much , and as much as I would like to tell everyone that the "BEAST" makes a kajillion kw's , the proof is on the road.
The car runs smoothly like a bat out of hell !
At least now I have a baseline , I am very impressed with Izak and will take it back to him everytime that I modify something for another run on the same dyno , then I can see improvements.
:wink:
ljS14
Car: Evo
Real Name: Shane
Post by ljS14 »
Strong like Bull 8)
Congrates :wink:
just make sure that you get Dynotech to get a reading after every mod,to see what the improvement is. If you do it elseware and you get 250kw for a small mod you know its a little out :lol:
My Sx makes 268kw on that dyno so i know its accurate too 8)
1991 S13 200SX
Evo 8
Andrew.200SX
That is exactly why I said that I will only take it to Izak , that way I know it is the same machine and the readings will reflect a gain or a loss.
Your's is Lekker strong !! :lol:
RB I presume ? :roll:
