MAF VS MAP
Posted: Tue Oct 19, 2010 12:35 pm
by aep886
should i delet my air flow meter or use Q45 MAF or Z32 MAF instead???
Re: MAF VS MAP
Posted: Tue Oct 19, 2010 12:50 pm
by Tobie
aep886 wrote:should i delet my air flow meter or use Q45 MAF or Z32 MAF instead???
I have had both, and I must say the fuel economy and smooth driving characteristics of MAF is a plus point.
But that is only my experience, others may have had it the other way around?
What ECU?
Re: MAF VS MAP
Posted: Tue Oct 19, 2010 5:54 pm
by aep886
Tobie wrote:aep886 wrote:should i delet my air flow meter or use Q45 MAF or Z32 MAF instead???
What ECU?
but the turbine i am after is a HKS GT3037S-pro...
only choice of ECU here in SA would be Apexi power FC
Posted: Tue Oct 19, 2010 7:51 pm
by cape town drfter
Q45 90mm
on my S14 with Nistune board.
Drives like a STD vehicle,smoooth..
Re: MAF VS MAP
Posted: Tue Oct 19, 2010 8:47 pm
by hentiebez
aep886 wrote:Tobie wrote:aep886 wrote:should i delet my air flow meter or use Q45 MAF or Z32 MAF instead???
What ECU?
power fc d-jetro no maf
Posted: Wed Oct 20, 2010 6:44 am
by Pinkfluffybunnys
Using MAF on both the SX and the Sentra.
Posted: Wed Oct 20, 2010 7:58 am
I am using map and with my unique tuning abilities
my ride is smooth...
Posted: Wed Oct 20, 2010 11:32 am
by aep886
Draco wrote:I am using map and with my unique tuning abilities
how unique ^^
Posted: Wed Oct 20, 2010 12:08 pm
aep886 wrote:Draco wrote:I am using map and with my unique tuning abilities
how unique ^^
Thats what I said...
Posted: Wed Oct 20, 2010 2:57 pm
by Guy
Have a look at the Link G4 ecu. I have the plugin version for my CA, and I'm planning to run maf. Engine build not finished yet.
Posted: Sat Oct 23, 2010 11:10 am
by thekoukimonster
Im running Nistune , happy so far
but im thinking of running apexi d-jetro in future, all is good and well,
but just like Nistune, who can tune Apexi
Posted: Sun Oct 31, 2010 9:34 am
by POWDER
I agree with Draco, MAP is better, more precise tuning abilities.
MAP: Manifold Absolute Pressure Sensor, which in turn means that your ECU will always know EXACTLY how much air is in the manifold, thus measuring out the precise amount of fuel every time. Also another upside is that there is nothing that can affect the calculation as the fuel measurement is done after the throttle body plate.
MAF: Mass Airflow Sensor, The MAF usually works on the principle of air temp, thus meaning that the will calculate the air density based on temperature, it will also calculate the rate at which the air cools the "Hot Wire" thus working out how much air is passing. The problem with this is that the calculation is done before the turbo and as such before the throttle body plate. This means that for example, if you have an internal dump valve that recirculates the air back in front of the turbo, your fuel calculations will remain safe but if you dump to atmosphere, you will end up running very rich for a few milliseconds, which in turn could give you a lagging feeling or a stuttery feeling and even cause more backfiring that usual.
All in all, with MAP your fuel is precises and you can play as much as you want, with MAF you can end up causing damage if you play around to much.
To me, MAF perfect if you keep your car standard & MAP the best if you know you will end up going all out like half of us do. But dont fret my friends, most after market ECU's have MAP sensors built in.
(PLEASE NOTE: I do not make assumption that I am 100% correct, if I can be corrected on some points, please do..)
http://en.wikipedia.org/wiki/MAP_sensor
http://en.wikipedia.org/wiki/Mass_flow_sensor
