100W globes
100W globes
If I used 100W globe is the ANY chance of them burning out the switch?? I ask this because on cars like the Opels and the old Alfa's you had to run them through relays or they did burn out the switch.
Toby
Club Founder
Real Name: Toby Kurien
Post by Toby »
Not just the switch, you'd melt the globe connector too.
But Freddie and Veecee (I think) are both running 100W globes. I know about the switch but never heard about the connector.
Post by Vlade »
ummmm not sure what Wattage those Osram Pure white stuff is, but I have been running them long time no problem.
me too... long time, one time, no problem, no problem!!!
VC are you running 100W globes or the 50W Osram pure white??
Gary57 wrote:VC are you running 100W globes or the 50W Osram pure white??
i think they are 90W pure whites, or 95W.
not quite 100W, but its close!
I got mine from freddie, so think they are 100W but could be 90W. How long have you had yours for??
Toby
Club Founder
Post by Toby »
Have the guys running high wattage globes ran them continuously for many hours (like on a long drive?) Wouldn't want to find out that your connectors got stuffed up half way to Durban! Also, have you guys inspected the globe connector for damage?
Why would the globe connector get stuffed by using 100W globes?? The only difference is they are flowing more current through them. I suppose they would get a bit hotter but not by much.
The Calibrator
Post by The Calibrator »
Ahem!
The bright beams run through a relay on all modern cars so you should be fine.
HOWEVER make sure you get 55/100w globes as the dims run through the switch and you stand a good chance of melting it if you fit 90/100w globes.
Been there done that paid the school fees
Not sure if the sx has the brights on a relay because I cant find them. Not any of the relay boxes say anything about brights.
Desertrat
Post by Desertrat »
My one connector burnt after about a year but it is not that hard to fix, I am using 100w.
had 92 200sx, had 93 240sx, had BMW 330D, had 97 Prelude, Audi RS6.
I pulled out the FSM and checked the wiring diagrams and they do run through relays even though they are labled as HL RETRACT 3/4.
