z32 brake upgrade
nirvash
1.0 Bar Boost
Real Name: Andreas
z32 brake upgrade
Post by nirvash »
hey guys
want to do the z32 brake upgrade with the 4pot front, 2pot rear calipers.
just wanted to know what i will need for the upgrade?
calipers
disks
pads
then i'm not sure, will i have to get:
new brake lines (and must they be z32 brake lines or 200sx ones?)
brake master cylinder, will i have to upgrade to the z32 one?
will i need the z32 e brake assembly and lines
anything else?
thanks
Current. CA18DET S13
NIZAN-R
Real Name: Renier
Post by NIZAN-R »
calipers f+r
rotors f+r
pads f+r
if you have a bm44 brake master it wil work for upgrade bm50 is better peddal feel and response
brake lines are good upgrade helps with peddal feel and response
if you have drum hand brake like most sa sx's its the same as z32/r32 no need to change.
5 stud conversion?if not you can dril the rotors to 4 stud
nirvash
1.0 Bar Boost
Real Name: Andreas
Post by nirvash »
thanks man
appreciate the help
heard really good things about this brake upgrade, have youve done it to your sx right? your opinion on it?
nirvash
1.0 Bar Boost
Real Name: Andreas
Post by nirvash »
had a look at my brake master cylinder earlier to try find out if it is a bm44 but it doesnt say or anything on it, how can i tell which one ive got?
n1smo200sx
Post by n1smo200sx »
I did the conversion also-still got stock BMC which is 16/17,I need the 1 1/16 that the Zx came out with.
Pedal feel is good with SS lines-stock lines won't work.
Front rotors is very difficult to find if you not going bigger than S14 .
a set of floating rotors will be about 6K plus 1.5 K for the offset bracket
if you can't do it yourself.
I have a set of front calipers available-3K.
Rebuild kits also-R450
the rears is already sold -but can sourch some if you need.
If you add up the conversion it will be
Calipers 5K
rotors 4K
SS lines 1.5K
Yellow stuff 2.5K
Ate racing brake fluid-R300
Rebuild kits R900
Respray calipers -R500
ZX BMC- R1500.
So it will quickly add up to a set of wilwood calipers and rotors in my opinion.
It is totally worth it when you feel the difference though in stopping power compared to stock,and looks ofcourse.
nirvash
1.0 Bar Boost
Real Name: Andreas
Post by nirvash »
thanks for the info n1smo
already sourced some F+R z32 calipers on ebay, just looking around at prices and so on for all the other bits
how does it feel using the stock BMC?
Skylinefreak
Post by Skylinefreak »
Holy crap Nismo where do you get your prices from? I'm doing S14 front brakes into a R31 Skyline. Costs to date:
S14 front calipers and discs R3k
Paint calipers R100
Redrill discs to 4 stud R240
Caliper brackets and new bolts R820
EBC Yellowstuff pads R950
Machine hubs & new bearings R650.
nirvash
1.0 Bar Boost
Real Name: Andreas
Post by nirvash »
so far the prices of things ive got my eyes on
z32 calipers all 4 corners, 3k-already ordered :D
then rotors=2k
ss lines +- 1k
front caliper rebuild kit for both R400
disk redrill R250
then still looking at pads n rear rebuild kits
nirvash wrote:so far the prices of things ive got my eyes on
then rotors=2k
ss lines +- 1k
disk redrill R250
Nice not bad dude!
Where you getting the rebuild kit? as I need one too...
n1smo200sx
Its for front and rear rebuild kits and brakepads.
When those calipers land you going to pay at least 1K import duties.
And Im talking everything new except the calipers,not 2nd hand stuff.
Also crossdrilled rotors,not OEM.
Riekert please tell me where you going to find 4 rotors plus shipping for 2K,I need a set also!
The pedal gets a bit long after a few laps,but normal driving you don't really notice it.
In my opinion the best upgrade is a set of 350Z brembo's and the stock discs.The are a bolt on fit and way bigger than the puny S14 front discs.
S14 brakes and rotors look pathetic with 18" wheels on your car.
Also 350Z pads are R500 cheaper than S14 Yellow stuff from dealers in Jhb.
nirvash
1.0 Bar Boost
Real Name: Andreas
Post by nirvash »
ebay, 29$ for the kit then 15$ shipping to S.A
all nissan oem parts (or so it says)
thats for both front calipers
http://cgi.ebay.com/ebaymotors/OEM-NISS ... ccessories
are you runnig z32's just up front?
also if i order a kit should i just order 2 then?
nirvash
1.0 Bar Boost
Real Name: Andreas
Post by nirvash »
you guys think this is just ebay crap or worth a try
http://cgi.ebay.com/ebaymotors/90-96-Ni ... ccessories
"Our rotors come with a 1 year warranty against any warping and a lifetime warranty against cracking of any kind. Simply send them back and we'll replace them for FREE"
Nice find there. I'm still looking for disc's for my Z32 calipers.
couldn't say how good they are however
nirvash
1.0 Bar Boost
Real Name: Andreas
Post by nirvash »
but with the warranty and price i think i mite put them to the test to find out :?
n1smo200sx wrote:Riekert please tell me where you going to find 4 rotors plus shipping for 2K,I need a set also!
donno? was just talking about the rebuild kit... thought that would cast more to the R800 mark.
nirvash wrote:ebay, 29$ for the kit then 15$ shipping to S.A
mmm... when you ordering... will only be able to take a set at the end of the month.
