The ultimate in electronic boost control is incorporated in our multi-tasker, the PRofec e-01. Designed as a combination boost-controller, data display/logger and original e-manage programmer. The e-01 can provide superior boost response, increased boost, warning meter functions, 3 channel data-logging and access to programming features provided with the e-manage support tool. Even when used as a boost controller only, the e-01 has features to smooth out the boost curve. With both an auto and manual setting for both external and actuator style wastegates, the PRofec e-01 can alter its compact, high capacity solenoid valve via various RPM ranges. The large LCD screen with green electro-luminescent backlighting is easy to see. Other standard features include two preset boost levels, a timed over-take boost and compatibility with our Remote Switching System. The data display can view 3 different data channels simultaneously such as boost, RPM or any other channel inputted by the e-manage. The data can be logged up for 3 hours on an SD card while also giving warning set points and peak and hold values. There is also a non-PRofec e-01 version that is only used for e-manage programming and datalogging. (Some features require optional harness to be accessed.)
BRAND NEW WITH 1 YEAR GUARANTEE, R4500 SHIPED ANYWHERE IN RSA, PM ME IF YOU HAVE ANY QUESTION, THANK YOU.
