boost problem
Posted: Wed Sep 29, 2010 7:16 pm
by aep886
my turbo spool up @ 3k rpm... i can hear the turbine is spooling up... but i dont feel any push from the car... what could went wrong? boost pipe or leaks???
Posted: Wed Sep 29, 2010 7:31 pm
by Ero_sennin
boost pipe pulled out some where?
Posted: Thu Sep 30, 2010 6:58 am
Ero_sennin wrote:boost pipe pulled out some where?
+1
Posted: Thu Sep 30, 2010 7:50 am
Have you got a boost guage? what does it say?
Is your manifold not leaking?
Re: boost problem
Posted: Thu Sep 30, 2010 12:40 pm
by Guy
aep886 wrote:my turbo spool up @ 3k rpm... i can hear the turbine is spooling up... but i dont feel any push from the car... what could went wrong? boost pipe or leaks???
The engine is in the front, you won't feel a push, you'll feel a pull...
Re: boost problem
Posted: Thu Sep 30, 2010 12:43 pm
:D :D
Posted: Thu Sep 30, 2010 1:16 pm
by Jacquesopper
Have a look at the actuater arm , see if it is still on and if the clip did not fall off.
Re: boost problem
Posted: Thu Sep 30, 2010 4:11 pm
by aep886
car is RWD... so it is a push
Posted: Thu Sep 30, 2010 4:13 pm
by aep886
Draco wrote:Have you got a boost guage? what does it say?
i have a boost guage... it boost 1.0bar @ 3k rpm....
Posted: Fri Oct 01, 2010 8:38 am
Mine did the same...I could see 1 bar on the guage but car did not feel like it was boosting, the exhaust mani was leaking....
Does the boost stay at 1 bar through higher revs and does the car rev?
Posted: Fri Oct 01, 2010 10:09 am
by djtreble
You not maybe just getting use to the power?
If you guage is showing 1 bar as it should at 3k rpm, either you have a shite guage or you are just use to the power.
If the mani or any pipes were leaking, then the car wouldnt hit full boost at the usual rpm (3k in your case I pressume).
What guage are you using?
What is your setup?
Posted: Fri Oct 01, 2010 12:02 pm
by aep886
djtreble wrote:You not maybe just getting use to the power?
What is your setup?
now it hitting 1 bar @3,5k rpm
autoguage...
factory setup
Posted: Fri Oct 01, 2010 12:05 pm
by djtreble
If it's moved from what it was then leaking manifold and/or boost pipes is more than likely your problem.
Is the turbo sounding any different to what it did before this?
Posted: Fri Oct 01, 2010 12:28 pm
by aep886
Draco wrote:Mine did the same...I could see 1 bar on the guage but car did not feel like it was boosting, the exhaust mani was leaking....
when the turbine spool up... rev is not going like it use to be
Posted: Fri Oct 01, 2010 12:31 pm
I'd bank on a leaking exhaust mani....but a boostpipe can also be the problem...
