boost problem
- aep886
- Real Name: Davey
boost problem
my turbo spool up @ 3k rpm... i can hear the turbine is spooling up... but i dont feel any push from the car... what could went wrong? boost pipe or leaks???
Re: boost problem
The engine is in the front, you won't feel a push, you'll feel a pull...aep886 wrote:my turbo spool up @ 3k rpm... i can hear the turbine is spooling up... but i dont feel any push from the car... what could went wrong? boost pipe or leaks???
- Charlvdw
Re: boost problem
Guy wrote:The engine is in the front, you won't feel a push, you'll feel a pull...aep886 wrote:my turbo spool up @ 3k rpm... i can hear the turbine is spooling up... but i dont feel any push from the car... what could went wrong? boost pipe or leaks???
- Real Name: Jacques
- aep886
- Real Name: Davey
Re: boost problem
car is RWD... so it is a pushGuy wrote:The engine is in the front, you won't feel a push, you'll feel a pull...aep886 wrote:my turbo spool up @ 3k rpm... i can hear the turbine is spooling up... but i dont feel any push from the car... what could went wrong? boost pipe or leaks???
You not maybe just getting use to the power?
If you guage is showing 1 bar as it should at 3k rpm, either you have a shite guage or you are just use to the power.
If the mani or any pipes were leaking, then the car wouldnt hit full boost at the usual rpm (3k in your case I pressume).
What guage are you using?
What is your setup?
What is your setup?
- aep886
- Real Name: Davey
now it hitting 1 bar @3,5k rpmdjtreble wrote:You not maybe just getting use to the power?
What is your setup?
autoguage...
factory setup
