Starts idle's but wont rev up
Shikar
Post by Shikar »
Starts idle's but wont rev up , when i press the accelerator it cuts out , its a s13 ca18det
Have you checked the ECU for fault codes? didn't think so. you should start there.
At what RPM does it cut out? A faulty AFM wont let your engine rev over 2000rpm...but it doesn't cut out however.
Skylinefreak
Post by Skylinefreak »
Also check your sparkplug gaps - try 0.8mm
Shikar
Post by Shikar »
Plugs are at 0.8 no codes and i've got 2 amf tried both need help
Ok can you give us a break down on everything you've checked. exactly what the problem is? ECU code 55? your sure?
checked the compression, checked the spark plugs, checked the coils, tested the CAS, checked the fuel pressure??
VegetaSSJ4
Real Name: Philip Broodryk
Post by VegetaSSJ4 »
Check your inter cooler piping.
I had the same thing a couple of months ago, i drove home one day and the next day when i started my car it started fine but when i tried to rev it it just died.
I started to stress that i broke something then i noticed that i popped a boost pipe of by my inter cooler.
have a look you never know
---------SKYLINE---------
(O O) - - R33 - - (O O)
----------FTW!!!!----------
Shikar
Re: Starts idle's but wont rev up
Post by Shikar »
VegetaSSJ4 wrote:Check your inter cooler piping.
it dose not rev at all as soon as i press the accelerator it cuts off
any loose cabling going towards the coils?
Othewise check the vacuum lines... they tend to screw around too.
Shikar
Post by Shikar »
How can i check Fuel Pressure
Hexadane
Newbie
Post by Hexadane »
Have you checked that the injectors have the right cables on??
:lol:
Shikar
Post by Shikar »
How do i check the fuel pressure
suske
Post by suske »
to check your fuel pressure you will need a t piece pipe and a fuel pressure gauge which you prob dont have, but if you do you should check the pressure and the inlet fuel line just after your fuel filter and then on the return line
THEO 3K - ZN
Post by THEO 3K - ZN »
I had a similar problem, it was my plugs, they were wet.
MITSUBISHI TRITON 2.4 + VAT
200SX - 1.8T
OPEL CORSA UTE
MK1 GOLF - 2L 8V
GENERAL TURNING & MILLING
THREAD REPAIR & STUD REMOVAL
QUEENSBURGH TRADING
djtreble
Post by djtreble »
I second the intercooler piping. Would be caused by the AFM reading air but not going to the engine due to big leak, engine dies immediately.
www.rotawheels.co.za
www.kaihatsu.co.za
