injector seals???
Posted: Mon Sep 20, 2010 1:36 pm
by Rossi-sx
standard CA18det injectors,where is the best place to get a seal kit?
Obsession maybe you can help?
Got a pretty bad fire hazard
Thanx
Posted: Mon Sep 20, 2010 1:39 pm
by poizen
its just a viton oring any seal place will hel you and will cost less than R1 each
Posted: Mon Sep 20, 2010 2:09 pm
by Rossi-sx
ha ha thats awesome got the perfect contact for that then prob get them for free
Posted: Mon Sep 20, 2010 4:29 pm
by nirvash
i also need some of those for my RB25DET, apparently can use SR20 ones, any idea if this is true or should i just go to a seal place like you said?
Posted: Mon Sep 20, 2010 4:35 pm
by Rossi-sx
well im gonna pull the seals out and take them along as samples and see what he says
Posted: Mon Sep 20, 2010 4:54 pm
nirvash wrote:i also need some of those for my RB25DET, apparently can use SR20 ones, any idea if this is true or should i just go to a seal place like you said?
i think you can
Posted: Mon Sep 20, 2010 7:21 pm
by nirvash
i think i'l do the same, just need to find a place in cape town, where abouts are you?
Posted: Tue Sep 21, 2010 7:54 am
by Rossi-sx
Im in East London,if i come right ill let you know
Posted: Tue Sep 21, 2010 7:55 am
by poizen
nivash sr20 injectors are side fed so no you cant use the same seals
any bearing or seal place will have these just look in your yellow pages
Posted: Tue Sep 21, 2010 8:00 am
poizen wrote:nivash sr20 injectors are side fed so no you cant use the same seals
RB25 are side feed injectors
Posted: Tue Sep 21, 2010 8:01 am
by poizen
i thought he ment with the ca18 to the sr seals
