Anyway - completely in two minds at the moment. This car was built by Rudeboy, and put back together by myself and Sergio from Docs Tech.
No expense has been spared - guaranteed! the spec is absolutely huge!
Guys no low ball offers - id rather keep it.
If anyone wants something special, that has potential to run 10's on a prepared track (already run 11.3 at Aldo Scribante), can beat 1000cc Superbikes - see video, and has every single top notch part then this is for you.
Im after R175k
Which might seem a lot, until you start pricing whats gone into it - which is a lot more than that.
Anyway - enjoy the pics, vids and spec sheet. PM me if you keen!!
Original Build Link
http://tobykurien.com/phpBB2/viewtopic. ... sc&start=0
New Updates Link
http://tobykurien.com/phpBB2/viewtopic.php?t=5650
Video of 1000cc CBR getting chowed!
http://s486.photobucket.com/albums/rr23 ... xvscbr.mp4
Dyno Video:
dyno1.flv video by ET000 - Photobucket
Spec:
Engine:
RB25det
Supertech valves
Tomei valve springs and titanium retainers
Ceramic coated exhaust manifold
76mm downpipe
CP pistons and Eagle H-beam conrods
1000 RC injectors x 6
Garrett GT35BB Turbo
Turbosmart Pro-gate 48mm wastegate
Cometic head gasket
N1 oil and water pumps
Greddy timing belt
Greddy fuel rail
Tomei oil pump drive & oil gallery orifice
ACL Race bearings
ARP studs (main / head)
TurboSmart fuel pressure regulator
External Walbro pump
Greddy copy intake
85mm Chevy Lumina throttle body
Tomei 256 poncam camshafts
MSD Ignition coils and Dis 4
s/s plumbing + exhaust
KoyoRad radiator + dual flexalite fans
Transmission:
RB25 Fatboy Box
Fidanza Alu flywheel
ClutchNet pressure and clutch
Suspension:
D2 coilovers
Tein control arms
Greddy strut bars front and rear
Wheels
Tenzo 8j and 9.5j 18's cut slicks (old)
HRE 8j with Bridgestons
Brakes:
330mm Wilwood Discs
Alcon Calipers
Yellow Stuff Pads
Management:
Dictator
Interior:
6-point roll cage
Hi / Low Boost Switch
Cobra Technology seat with 4point Scrotch fia harness
Sparco steering wheel
Vems EGT + AFR gauge
Performance: (Over 2 bar Boost)
550KW and 825 NM
Current Power at the wheels
234kw at 0.7bar and 394kw at 1.28bar
