Precision Billet Comp Wheel Turbo's (non Ball Bearing) - R8800*
39mm Wastegate - R2699*
46mm Wastegate - R3499*
If you do a bit of reading the results from the Precision Billet Turbo's Speak for themselves!!
Normally all Turbo Orders are custom built at the Factory for me.
So its not often you find the Turbo's lying around in Stock.
From order, It takes +-7 Working days until your Turbo is here, If PRT have the needed housings in stock Etc..
The only Turbo in Stock left from the Batch that just went out to customers is a 5857 Billet, Which might go to a RB25DET owner tomorrow
For All Questions / Info & Orders - EMAIL ME !
About Precision Turbo & Engine
Since 1987, Precision Turbo & Engine has been a leader in turbocharger technology for street and race applications. Just recently, Precision Turbo customers were the first to break the 6-second barrier in Sport Compact racing and have won championships in NHRA Sport Compact Pro RWD and Hot Rod categories. Precision Turbo has also set numerous records and won championships in a wide array of sanctioning bodies ranging including Fun Ford, NDRC, NMRA, NOPI, NSCA, Pro Hot Rod and PSCA. Precision Turbo customers have also found great success in the world of road racing, drifting and even on the Bonneville Salt Flats.
Precision Turbo & Engine offers a full line of custom turbochargers, accessories, intercoolers, fuel injectors and stand alone engine management systems. Precision Turbo offers products for a wide variety of vehicles ranging from Buick Grand Nationals to Nissan Skylines.
39mm Wastegate
With over 60 years of combined turbocharger development and racing experience, Precision Turbo has taken great pride in providing you with the best external wastegate on the market today. The Precision Turbo PW39 is made from high grade, high temperature stainless steel and billet aluminum components. It features Precision Turbo's own purpose designed Kevlar reinforced wastegate diaphragm and a 347 stainless investment cast valve body. Precision Turbo's investment cast valve body has a smooth internal surface, giving you better flow and more accurate boost control. The Precision Turbo PW39 was designed to be a direct replacement for other existing 38mm wastegate flanges, but will work best with the flange provided. The PW39 features a Nickel Chromium Alloy valve and 5 different 17-7 precipitation hardened springs. Also included are stainless steel inlet and outlet flanges with clamps. With a satin black anodized, 6061 aluminum billet wastegate cap you will have years of good looks and protection from the elements. The PW39 is generally compatible with most aftermarket manual and electronic boost controllers on the market today.
46mm Wastegate
These Precision Turbo 46mm Wastegate units feature a 46mm valve, and can be used in a wide variety of applications. Precision Turbo Wastegates can be used in any kit or setup that currently utilizes a v-band style 44mm gate (Tial 44mm or Synapse 50mm), but will work best with the supplied inlet flange (the inside diameter of our flange is slightly larger than our competitors). Precision Turbo wastegates will be shipped with all the necessary hardware (flanges, clamps, springs, etc), and can accommodate a wide range of boost pressures (anywhere from 1.5PSI up to 25.5PSI). All units feature a black, anodized wastegate cap, and a Kevlar reinforced silicone diaphragm. In addition, the unit features a five angle valve job, as well as high temp 17-7 ph springs (more durable and can withstand higher temperatures before changing rate). Lastly, the Precision PW46 is set up for a 1 3/4" pipe on the discharge side, and a 1 7/8" pipe on the inlet
