VG30E and VG30ET
VG30E and VG30ET
For the boffens....
I am finding it very hard to find a VG30ET(SOC turbo) motor, there are many VG30E motors for sale though.
Compression difference: VG30E = 9
VG30ET = 7.8
Compression pressure : VG30E = 1.196
VG30ET = 1.138
Bore and stroke are the same.
What would be the big worry about adding a turbo and bigger injectors, and obevously turbo manies.....do you think the motor will still be relyeble and how would it respond to say 1 bar boost vith the right fuelling and so on...?
P3g4sus
Club Drifter
Car: Supra
Engine: 2JZ
Real Name: B.G. Smit
Post by P3g4sus »
You will have to do something with the compression ratio at the very least, 1 bar would probably need new internals.
RB25SX
Post by RB25SX »
Should work. I have 3 x VG30ET motors here. Not sure if there are internal differences other than maybe pistons.
R32 GTR
MMMMM...are they in good condition....?
is it the later engines "W" blocks?
T3 or T25 turbo's?
What would you ask for an engine?
Planne?
beplanning vir die toekoms....
godzilla
vg
Post by godzilla »
copression wuld be the only issues.but these motors are so strong your could turbo charge it but not as high as 1 bar for reliability.or else change pistons to get the proper compression. we changed the heads of a on a vg30ET for port and polished wth bigger cams from a VG30E and it still runs well every day.so the heads are prbably exactly the same .
sideways forever....
The cams is the same...eroepean engines in any case, the head as well, the only diffs according to the manual is the valves "angle" where it seats and the thickness of thbottom of the valve because of the angle.
godzilla
vg
Post by godzilla »
y not give it a try. i wasconsidering this mod a wile back but then id get so greedy for more boost id end up destrying yet another motor lol
I am planning to....just need the funds to be right first....I've been speaking about this swop for a while...if I need to, I can always add the forged piston kit for the Z32....when I win the lotto...
RB25SX
Post by RB25SX »
From what i read, the std motors are good for 450-500hp. Guys do 450whp on std internal VG30ET's in their Z31's.
The ones i have, has T3 turbo's on. One must go into my Sani 4x4, will get a RB25DET B/B turbo & 370 inj's for quick responce and about 200kw.
R4000 if u want one.
R32 GTR
You don't perhaps have gearboxes aswell?
RB25SX
Post by RB25SX »
Draco wrote:You don't perhaps have gearboxes aswell?
No, they are pricey, R6K for box with flywheel & clutch from Mikes place in Ctn.
R32 GTR
Ok....I'll track you down when I am ready....
RB25SX wrote:From what i read, the std motors are good for 450-500hp. Guys do 450whp on std internal VG30ET's in their Z31's.
hehe :D
