VoLcOm
Posts: 30 Joined: Wed Oct 31, 2007 11:58 am
Post
by VoLcOm » Tue Aug 10, 2010 12:47 pm
Hey guys, i need some advice please. My anti lock light came on and my abs pump is not switching off when i switch off the ignition, it keeps on running. I had to plug it out. Any ideas what can be wrong?
300sx
0.8 Bar Boost
Posts: 882 Joined: Wed Apr 30, 2008 5:24 pm
Post
by 300sx » Tue Aug 10, 2010 9:00 pm
possibly the abs controller(ecu).. i have had to replace mine once before..
300zx fairlady 1991
200sx s13 with vg30det @ 1bar
VoLcOm
Post
by VoLcOm » Wed Aug 11, 2010 6:36 am
How much does it cost?
poizen
Posts: 2994 Joined: Sat Apr 12, 2008 2:05 pm
Real Name: Mical Mackay
Post
by poizen » Wed Aug 11, 2010 7:02 am
VoLcOm wrote: How much does it cost?
a;ot hahhahaha we drive nissans here were nothing is cheap
djtreble
Posts: 1502 Joined: Fri Jan 29, 2010 2:49 pm
Post
by djtreble » Wed Aug 11, 2010 9:28 am
Remove the ABS...weight saving ftw
andre_sx
Posts: 1225 Joined: Fri May 08, 2009 10:25 am
Post
by andre_sx » Wed Aug 11, 2010 9:57 am
the abs unit should be around R1,000,000.00
VoLcOm
Post
by VoLcOm » Wed Aug 11, 2010 10:20 am
hehehehehe no really now what does the ecu cost?
300sx
0.8 Bar Boost
Post
by 300sx » Wed Aug 11, 2010 10:23 am
its not even so much a question of how much, its even just gonna be a mission to find the controller in question.. unless you can get vaseline at discount and want to ask the stealership
anyways with the symptoms you described it i would guess at one of 2 things like i said, most prolly the controller, or might even be the abs unit itself (shorted solenoid,contacts ect.)
the FSM describes a procedure whereby the abs ecu can be put in diagnostic mode , maybe it will give a few error codes which will shed more light on the issue..
300zx fairlady 1991
Posts: 3882 Joined: Wed Jan 09, 2008 10:08 am
Post
by Charlvdw » Wed Aug 11, 2010 10:44 am
I took mine out last weekend, the ecu still needs to come out. If you are interested.
VoLcOm
Post
by VoLcOm » Wed Aug 11, 2010 1:23 pm
How much do you want for yours?
Post
by Charlvdw » Wed Aug 11, 2010 1:40 pm
PM sent.
wez_sx
Posts: 39 Joined: Thu May 15, 2008 10:07 pm
Real Name: Wesley
Post
by wez_sx » Fri Oct 29, 2010 11:09 am
Hey i had the same problem about a year ago, its the 1 of the 2 abs relays under the black cover on the abs unit. its a cheap fix i think it was like R30.
aep886
Posts: 1881 Joined: Thu Aug 09, 2007 10:19 pm
Real Name: Davey
Post
by aep886 » Fri Oct 29, 2010 8:25 pm
DAMN... my ABS light also comes on now....
200SX MP
Posts: 219 Joined: Thu Jan 25, 2007 1:35 pm
Post
by 200SX MP » Sun Oct 31, 2010 6:11 pm
wile on the topick mi anti loick light stays on and i dont have ABS wat so ever
RB 250 SX
Posts: 936 Joined: Wed Oct 06, 2010 12:23 pm
Real Name: ????
Post
by Adrian » Mon Nov 01, 2010 12:52 pm
my light did the same all i did was top up my brake fluid because it was just below minimum
