ECU fault codes - 34 knock sensor
the new symptoms are reliable and wont go away. the car is fine and is running better than ever for the last few days except:
1. i am prevented from revving the engine up at all, as soon as it gets hot. it idles perfectly, but goes whap..............whap.............whap..........whap instead of revving up. and this is past idle. so from about 1000rpm it does nothing - even if the accelerator is completely open.
so i hauled the ecu out to check for fault codes. i got code 34 on mode 3. this is the knock sensor. so i followed the instructions for checking the sender. the sender is fine, and the continuity of the cable seems fine.
so i reset the computer and unplugged the knock sensor this time. the car ran like it did before, and once it got hot (about halfway on nissan temp gauge - and about 100-110 degrees on my guessometer) it stopped me from going over idle at all.
any ideas - what about unscrewing knock sensor, and wiring it up, but keeping it out of the engine block?
i am very close to getting rid of this problem the ol'skool way!!!!
please help if you can.
Post by Vlade »
you need to keep the knock sensor plugged in at all times... the sensor uses a shielded wire, be very sure that the signal wire does not short with ground (I had this problem).
If the knock sensor is not connected it throws the ECU into a different map (for safty so it over fuels and retards engine).
My personal opinion i think you might have an ignition problem spark at greater RPM, its easy to get spark at low RPM I think your ignitor or coils are dying down higher up.
The wobbly RPM can be numerous things with the stock ECU it uses a whole bunch of things to try and stabilize RPM, I'll personally just double / tripple check all the connectors.
VC I am not pretending to know what your problem is, this is what I found, I had a miss on about 4500 revs, it didn't want to rev higher because it started "spattering" or spitting whatever you want to call it, this is after I readjusted my spark gap from 0.6 to 0.8( BCR8ES) bacause the plugs showed me that the car is overfueling and the plug was not burning the carbon off.
I then replaced it with other ones I had but set the gap to 1mm, then it started to miss on idle and a slight miss on higher revs, I then went down to BCPR7ES and put my gap on 0.8, she seems fine now.
My point is, try hotter and colder plugs with different gaps, maybe you get lucky, I know I did, before I never had a problem with the BCR8ES plugs but that was because of the 0.6 gap, all that went wrong was overfueling, car drove like mad....then played with gaps and stuff and things started going wrong, I think somewhere you are loosing heavy spark.
Sorry if I typed alot of shit but these stupid little things made differenses to my car like the restrictor washer in the vent pipe that caused smoking on idle, was at turbo guys, tuners blablabla, took the washer out gone.
Small things keep chekking and see the resolt of changing something.
thanks guys - the more shit the better draco.
but you guys missed the fact that the car is running sweetly now. i have no wobbly idle, and i have no misfires.
i did change the plugs draco, back to the ones i had before the service. these are the ngk bcp6, and they were gapped to 0.8mm. so its going exceptionally well until it get warm, well, lemme say hot rather.
as soon as its hot, something fucks out and wont let me rev. i've heard toby saying that coils can give problems that only manifest when they are hot, so i originally thought it was this. but if there was a spark problem i would get a fault code on the ecu for the power transistor.
i have a fault code for the knock sensor - and as far as i know - that means that the knock sensor is faulty. with a faulty knock sensor the ecu will go into a different map like vlade mentioned. but whatever map this ecu is going into, doesnt even let me go from 1000rpm to 1100rpm. it idles beautifully, but goes whap whap whap above idle.
i dunno.
i have 3 spare coils - maybe i will try those this evening when i get home, but i hate that engine at the moment.
Ya when it is fine again you will love it again...it's a twisted world.
hang on, if you guys know please clear this up for me.
a fault code on the ecu means that a sensor or actuator or solenoid or something is faulty, NO?
or does it mean that the engine has detected a problem (like engine knock) and therefore has a different map loaded.
i think its because the ecu thinks my knock sensor is faulty, but i may be wrong?
Phinx
0.7 Bar Boost
Post by Phinx »
why do you run such small gaps? :?:
What boost do you run daily?
because i was having little issues when the standard gaps were installed.
changed it and it seemed to run much better.
while i was testing coilpacks, i was bitten on my hand by the spark from a spark plug, and to tell the truth - i didnt feel strong at all.
i always thought that it would throw me across the garage, but i didnt even let go of the coilpack. i just stood there, asking my appi to turn off the engine.
my appi says that once the same thing happened with his golf, and his hand hurt for some time after that!
i dunno - maybe those coils are too blame, but wouldn't i get a fault code on the ecu for the transistor then?
and why is the fault code for the knock sensor there then?
No you wouldnt
If i understand you correctly it sounds just like when i ran while the sensor was disconnected. The car ran ok, just hard to pull away, but with revs it was fine...albiet a little underpowered.
The ECU only picks up serious faults on sensors. it basically has to be dead.
You could try fooling the ECU into thinking the knock sensor is there. A 470K resistor should do the trick.
Daniel wrote: You could try fooling the ECU into thinking the knock sensor is there. A 470K resistor should do the trick.
i thought about this too, but i wasn't sure how to do it. thanks daniel.
so get the fault code, and i assume the sensor is stuffed. so i perform the test for it as per the manual, and it is apparently fine. go figure. it is a nissan after all!!!
if i clear the ecu's memory and start the car - the fault code is displayed immediately. but the revving up problem only starts after about 15-20 minutes of "spirited" driving!???!
BWAAAHAHAHA :lol:
I was hit by the coil while checking timing. It wasnt bad at all...so i dont think thats an accurate way to test coils either :roll:
i guess its not an accurate test - but i always thought that the number of volts from a coil should hurt a bit when you get shocked!!!
its supposed to be close to 40 000 volts isnt it?
i mean an electric fence is only 10 000 colts!!! sorry, volts - but thats funny enough.
WooHaa
0.6 Bar Boost
Post by WooHaa »
The ECU also has a real time mode. I suggest that you drive the car while cold & get it warmed up & as she starts getting hot get a dude to watch the ecu or get somebody to drive the car while you watch the ecu & see the codes that come up.
The car goes into a limp mode if there is a problem with your AFM. maybe the heat from the engine bay & stuff causes problems on a failing AFM.
Just a thought.
Steer From the Rear !!
WooHaa wrote:The ECU also has a real time mode. I suggest that you drive the car while cold & get it warmed up & as she starts getting hot get a dude to watch the ecu or get somebody to drive the car while you watch the ecu & see the codes that come up.
Just a thought.
its a good thought - we never got around to do the realtime test last night. will do that tonight.
i thought it might be the AFM too, but when the problem reared its ugly head, i unplugged it and the engine just died immediately. so i dont think its that.
The Calibrator
Post by The Calibrator »
A knock sensor fault will limit boost to 0.5ar and probably run a different timing map however the caqr will still drive normally.
U suspect a fuel issue ie: running lean.
While the car is in the warm up phase it runs a richer mixture untill hot when all temperature compensation is inactive.
Some more info would be helpfull. Does it emit black smoke while its going" whap whap"? If so it will indicate a rich mixture if no smoke it may very well be lean.
Stick a gas analyzer in the exh or a WB sensor and see what the mixtures are doing.
