S13 ca18det wont start got fault codes 13 , 34 will that be
Drove the car home parked it , the next day it just did not want to start , it's got spark and the timing it spot on , someone plz help btw im in durbs
Re: S13 ca18det wont start got fault codes 13 , 34 will that
the car swing but just dose not takeShikar wrote:Drove the car home parked it , the next day it just did not want to start , it's got spark and the timing it spot on , someone plz help btw im in durbs
Will a knock sensor cause the car not to start
- poizen
- Real Name: Mical Mackay
it will cause the car to go into a extreme retarded map as now it cant register a knockShikar wrote:Will a knock sensor cause the car not to start
i have a spare det sensor (holding it for a friend tho)
where in durbs do you stay
what sx you got
code 13 is just the coolent temp sensor will cause a slight fail safe mode try get a new one but make sure it has the yellow connection tho
hope you come right
how do you know timing is spot on who checked it
