wheel spacers
- poizen
- Real Name: Mical Mackay
wheel spacers
****UNDER REVIEW*****
will return shortly
will return shortly
- Skylinefreak
- 0.5 Bar Boost
- Skylinefreak
- 0.5 Bar Boost
- poizen
i think i have a s13 disc i have the 30mmx 280mm discsSkylinefreak wrote:I have two in my garage that was machined away to accept S14 discs but they took too much away. Maybe I should send them to you to make one specifically for a S14 brake conversion... Do you have a S14 front disc to measure the inside diameter that the hub should fit into?
send to me ill have a look
bump for spacers
- nirvash
- 1.0 Bar Boost
- Real Name: Andreas
i am so sick of trying to find the right pcd wheels with the right everything else, so when i find the right wheels (sometime soon hopefully) i will definitly be needing spacers, so i will let you know when once my search is over
thanks
thanks
Current. CA18DET S13
- poizen
I cam make new hubs will have to work out pricenirvash wrote:can you make pcd changers from one hole pattern to others?
lets say 4x114.3 - 5x114.3??
or would you have to make a completely new hub?
can you make new hubs, and if so what would they cost?
I have a pcd changer design but wnt try it on a customers car but will have to be min 30mm
- nirvash
- 1.0 Bar Boost
well those wheels that RB25SX just advertised about an hour ago seem like quite a bargain, just checking if they gona be wide enough, if they can run 245 0r 255 (8.5-9j) then i think im gona take hem, as long as you can make them fit
- nirvash
- 1.0 Bar Boost
30mm, nothing some fender rolling cant fixpoizen wrote:I cam make new hubs will have to work out pricenirvash wrote:can you make pcd changers from one hole pattern to others?
im quite desperate at the moment for some bigger wheels, my 195 tyre's at the moment dont like my RB that much
