as the title says, its brand new, sealed and never been used, not gona be using on my car so for sale.
Cometic C4318-051 Metal Head Gasket RB25DET 87mm x .051"
Cometic MLS (Multi-Layer Steel) head gaskets are made of 3 layers of stainless steel. Cometic uses stainless steel for increased strength, ability to rebound, and resistance to corrosion. The outer layers are coated with Viton and beaded for perfect embossment. Viton is a fluoroelastomer rubber-based material that can withstand 482°F and able to seal the most harsh environments such as high load conditions and different surface finishings. The center layer is uncoated which can be varied to accommodate multiple thicknesses.
•Ideal for aluminum heads on cast iron or aluminum blocks.
•Withstands shearing forces created by aluminum heads/cast iron blocks.
•No re-torque is necessary.
•Promotes an even torque load across the sealing surface, allowing for measurable reduced bore distortion.
price=R1900
