management needed
Posted: Tue Jul 06, 2010 7:38 pm
by 200SX MP
hi any one seling a manage ment thatl work in on a rb 25
Posted: Tue Jul 06, 2010 7:39 pm
by poizen
i have a gotech pro mfi v5 gold edition dont know if it will work
Posted: Tue Jul 06, 2010 7:41 pm
by poizen
info on the unit im selling will work 6cyld
Gotech-MFI © Terms of Use
Gotech MFI PRO Engine Control Unit
The Gotech MFI Pro system is an Upmarket version of the standard MFI ECU. This unit has additional features allowing greater control over Engine management. The ecu contains many more components providing for the greatly enhanced functionality. This ECU offers outstanding value for money and is much more than just "Competitively Priced"
Gotech MFI PRO Information and Features
Applications:
- 4 Cylinder wasted spark (60 -2, 36-1 or 24-1 Distributor pickup)
Two coil and two injector output
- 4 Cylinder wasted spark + MF (60 -2, 36-1 or 24-1 Distributor pickup)
Two coil and two injector output, One micro fueler output for extra set of staged injectors
- 4 Cylinder with distributor (Trigger per event or 60 -2)
Two injector and one coil output
- 6 Cylinder with distributor (Trigger per event or 60 -2)
Three injector and one coil output
- 6 Cylinder wasted spark (60 -2)
Three injector and three coil output
- 8 Cylinder with distributor (Trigger per event)
- 8 Cylinder two distributor (12-1 Lexus 1uz)
Two coil and two injector output. This setup is also available on a 60 -2 crank pickup. We recommend using 60 -2 if possible.
- Rotary twin rotor engines (24 -1 distributor pickup or series 6 crank trigger)
Three injector and Three coil output. The primary injectors are phased and the secondary are run on the micro staged fuel map.
Two GPO outputs, one for fuel pump or shift light and one for VVT.
Tach output
Launch control (Launch RPM limiter, Launch timing retard, Launch time delay, Launch fuel add %)
Closed Loop lambda control (Narrow band)
Posted: Wed Jul 07, 2010 7:47 am
I'm willing to sell my xms v3 as well ,open to offers.
Posted: Wed Jul 07, 2010 9:24 am
by andre_sx
how much for the gotech
Posted: Wed Jul 07, 2010 10:51 am
by Tobie
Gotech will work if you get a 60-2 wheel and pickup on the crank pulley of the RB25.
Posted: Sat Jul 10, 2010 5:44 pm
by poizen
andre_sx wrote:how much for the gotech
im looking for 1500 for the gotech
Posted: Sun Jul 25, 2010 3:13 pm
by 200SX MP
gotech v5 wont work foned gotech them selfs
Posted: Mon Jul 26, 2010 8:46 am
by 300sx
lol, ofc it will work, i have one running my vg30, unless im imagining it
