Cams for sr20det "notch" back needed
- Slide 'em Wide
- 0.6 Bar Boost
Hey i am looking for cams for my sr. either stockers or aftermarket.
What Id rather be dooing!
- Slide 'em Wide
- 0.6 Bar Boost
Car was running a bit lean and cams have damage. Fitted new fuel pump. and also found that the brick that owned the car b4 me removed the lamda sensor (Y?). so put that right. now the car has more power than ever even tho i dropped the boost. And the unfortunate side effect is excessive wear on the lobes of the cams. I figure im gonna do a basic rebuild soon so i needs them. I have a friend with a workshop that has all the machines. if the service is good ill give the guys on the forum the heads up...
