Rings??
Posted: Mon Mar 05, 2007 2:00 pm
by Daniel
How do you test for rings??
Compression is even on all cylinders albeit it low at 8.5bar, but that was with a cold test. the car smokes its ass off on boost. If i give it some welly i see the smoke in the rear view mirror and when i change gear theres one huge gigantic smoke cloud
Turbo has just been rebuilt and i can smell the oil. Plus the smoke is a little darker than when the oil seals are gone.
I think my actuator on the turbo is faulty or something. On teh way to work it boosted to 1.4 bar
fcuks off like that but eish thats not good. will check it wen i get home.
But how would i test for rings? im not in the mood to pull the engine again. And the bank manager doesnt want to pay for a new gasket set + rings and whatever
Still drives a feck load better than last year
Posted: Mon Mar 05, 2007 2:31 pm
by Daniel
fixed the crazy boost thing now
Posted: Mon Mar 05, 2007 2:37 pm
by johansx
Valve stem seals and or guides... ?
Posted: Mon Mar 05, 2007 5:53 pm
by The Calibrator
Cylinder leakage tester.
Posted: Mon Mar 05, 2007 5:59 pm
by Daniel
The Calibrator wrote:Cylinder leakage tester.
Thanks
could you explain a little more? where can i get one and how does it work.
Posted: Mon Mar 05, 2007 8:03 pm
by widowmaker
and have you removed that little breather washer thingie?
also thought my motor was shot - removed that restrictor and no more smoke - magic
Posted: Tue Mar 06, 2007 7:54 am
by Daniel
1st thing i looked for. Couldnt find it
It is in that short pipe going to the PCV valve right?
Posted: Tue Mar 06, 2007 9:07 am
No it is the restrictor washer in the turbo side of the tappetcover breather pipe going into your air intake from the air filter.
Glad I could help you out widowman....with the washer thing, I thaught I was the only 1 with this washer thing....I am not alone anymore!!!!
Posted: Tue Mar 06, 2007 9:18 am
by Daniel
OH! well that sux coz i dont have that pipe anymore anyway
sh1t
Posted: Tue Mar 06, 2007 9:44 am
If that PVC valve is blocked it can also cause to motor to smoke... but mostly on idle
Posted: Tue Mar 06, 2007 9:55 am
by Daniel
Checked that 2.
I cant believe the rings are gone, that engine looked so spotless. All breather pipes where clean, head was clean clean clean. pulled off sump everything was clean even the oil in there was pretty damn clean. the spark plugs even looked good. Only the waterlines looked rusty. Reckon i need a couple water flushes
Posted: Tue Mar 06, 2007 10:19 am
a little trick i heard of is to drip about a little bit of oil (clean) into your combustion chambers. it would be say 5ml's i think. then redo the compression test. if it goes up drastically then your rings may be stuffed.
but the leakdown test is the real way to do it.
Posted: Tue Mar 06, 2007 11:08 am
by widowmaker
didn't have oil left to drop in, so i used sugar
should work and it smells nice too
Posted: Tue Mar 06, 2007 1:29 pm
by johansx
What does the spark plus look like after a short run? Soot, lots of carbon or clean?
Posted: Tue Mar 06, 2007 1:36 pm
by widowmaker
sticky, but it smells like candy floss
burnt my tongue quite bad though
