Perfect Power
- Andrew.200SX
Perfect Power
Hey guys.
I need some assistance again. I have just fired up my S13 SR20DET after having removed the motor and doing a clean up. I also replaced the head gasket and had the valve stem seals replaced. In the process of doing this I noticed that the intake cam was out 1 tooth , so I corrected that, but here is my dilemma. The car has a Perfect Power XSM-L stand-alone management system. The car is now idling at around 2500 rpm and is spluttering , is this because the system was set up with the intake cam out 1 tooth and now needs to be re-tuned, and if so , who can check this out for me in the Cape Town area?
Thanks
Thanks
- Andrew.200SX
- Andrew.200SX
- 200sxrb25
- 0.2 Bar Boost
perfect power
Their is no one in CT to tune perfect power proper. I take my car to dyno tech. My suggestion is to fit gotech or dicktator.
200sx rb25
lotus 7
lotus 7
- Charlvdw
Re: perfect power
Which you cant really compare to Perfect Power but it is easier to tune so you will find more tuners.200sxrb25 wrote:My suggestion is to fit gotech or dicktator.
- Andrew.200SX
Thanks guys. I have however requested a coms cable from Perfect Power and I will download the software and in this way I will learn how to tune the car or go bust trying. If all else fails , I will look into a Diktator / Gotech or Nistune system.
- Andrew.200SX
- Andrew.200SX
Hey,what can I say .......... when you are thick ....you are thick. I had the Vacuum pipe from the Brake booster on in the wrong spot. Put it where it belongs and the idling is back to where it should be. Now I must just determine the cause of the miss. Plug , plug lead or injector.
I still need the coms cable for the management though please , if anyone has.
- Andrew.200SX
- Andrew.200SX
